Question about GPS
Tomtom130/135 very-very slow (30 seconds) start-up every time. How to correct
Posted by Leilani on
94 honda passport idles high every time i start it for 30 seconds
Normal as it is the same as pulling the choke on
once the ecm has run all the checks and the sensors have registered correctly then the ecm brings the rpm,s back to normal.
If it lasts for a longer period then run the fault codes but 30 seconds is about average
Apr 13, 2015 | 1994 Honda Passport
Clicking in dash and no hot air
Blower motor worn and weak, taking time to actually start due to worn out brushes in the blower motor. Change the blower motor. The clicking that you hear is actually the springs that provide tension on the brushes. Sounds like the brushes have fell out, leaving only the springs to provide the needed voltage. Springs rubbing the contacts will sound like a slow click click click at first, but will speed up as the motor shaft starts spinning faster.
Dec 08, 2013 | 2003 Chevrolet Impala
I paid $30 for an answer and found I was charged for the wrong answer! How can I make sure the answer I get is correct? I asked 1 question and 3 statements were made all incorrect! See below, Hi; I...
what are you asking ? Billy gave you a correct answer he says 30 seconds is desirable
Plus I only see one answer not three
Second I would not sign up anywhere that I have to pay for any info
Oct 13, 2013 | Heating & Cooling
How do you reset the timing on a 1998 VW Jetta?
a car of that year should have an ecu controlling fuel air mix etc. this normally controls the timing.
To reset the ecu on my '95 VW Golf disconnect the battery (negative / black terminal) for 15-30 minutes depending on who you ask. So I do 30 minutes.
If it has central locking make sure you don't leave the keys in the car when reconnect it. swich on the ignition without starting the engine so the dash lights up with the oil light etc. for 30 seconds then off for 10 seconds. then start your car. It will relearn so it will run a bit rough for a while but should settle down. take it for a spin on different types of road ie. slow and fast.
Nov 22, 2010 | 1998 Volkswagen Jetta
Two clocks are set at 6am one clock gains 30 seconds every hour and the second clock loses 1 minute every hour. at what time will the faster clock be 30 minutes ahead of the second clock
Compute the difference in clock-speeds, namely 90 seconds per hour.
Convert the units of time: 30 minutes becomes 180 seconds.
So, divide 180 by 90 to get '2', namely 2 hours after the 6 o'clock "start" time, which makes it 8 PM.
P.S. There is at least one error in the above solution. If you truly understand the solution, make the necessary correction, and submit the corrected "homework" to your teacher.
Jan 07, 2010 | M2K Garfield: It's All About Math Math...
SLOW TOSHIBA Laptop
hai
In ur laptop right click the C: and click properties ,then select disk cleanup follow the instruction and delete the unwanted files like temp files, cookies ,etc and ur system will increase its speed
Mar 03, 2009 | Toshiba Satellite L20-S310TD Notebook
GPS Logo
64 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
