Question about FUJIFILM Cameras
My FujiFIlm Finepix S2940 when powered only occasionally flickers the green light and lens comes out but then immediately powers off.
This has happened when installing brand new alkaline battery. I have it also plugged into a power source. Is it the battery type or did I just lose 60 bucks on a defunct camera?
Posted by Jackie Winchester on
Rob lowman
    Problem Solver:
  • 7 Answers
It sounds like there's a problem with the circuit board...
Posted on Nov 04, 2018
1 Related Answer
Ty Price
  • 11967 Answers
SOURCE: I have a Fujifilm FinePix A610 camera. This
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 28, 2010
Suddenly can't type in keyboard. Desktop computer. Brand new batteries. Must fix soon. Help!
I would take the batteries back out and put them back in. You may have put the batteries in the wrong way. Another thing you can do is to unplug the dongle that came with the keyboard and mouse. You can wait a few seconds and plug it back in. The batteries you are installing may be bad. Try installing another set of alkaline batteries. Try rebooting your computer, see if that helps. Your wireless keyboard and mouse may be going out. You can find new wireless keyboards and mice at Walmart, Best Buy, Office Depot, Etc.
Aug 14, 2016 | Computers & Internet
Olympus Camedia E10 won't power on with AA NI-MH batteries but works fine with AA ALKALINE, what can I do?
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Make sure your rechargeable batteries are all good. One defect in a set is killing for the whole set
Don't use barrettes from different sets or brands together.
I had one brand good NiMH batteries and a very expensive charger from the same brand. The charger destroyed all my rechargeable (more than 60 now). When I first discovered the batteries were dropping out, I stopped using the charger, but it did not prevent all batteries to die in the following months. Every time on dropped out I had to change the set. I tried using up the others by grouping the ones with the same Ri, but not longer then a few months and I had a box full to trow away.
Never use a quick charger, capable of charging them within an hour or faster. Us a charger that indicates the Ri is still low enough, so you can see what batteries are bad.
Check you are using a charger for NiMH batteries.
I would try another set (new) because buying Alkaline is also not cheap.
I used 2700 mAh and later 2600 mAh rechargeable, all dead now. since a few weeks I'm now using 2300 mHh from another brand, costing 1/5 of the "best" I had before, and they are doing great. I won't charge them with the quick charger.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights.
Apr 20, 2015 | Olympus Camedia Cameras
Low battery
The manual says:
The camera turns off immediately even when battery power is full.
The remaining battery power is low even if new batteries are inserted.
•The remaining battery power may not be displayed accurately, and the camera may suddenly stop working, when the type of battery and the settings on [BATTERY TYPE] are not identical. However this is not a malfunction. Depending on the battery
brand and the operating temperature, or if exhausted batteries are used, the remaining battery power may not be displayed accurately.
and:
Use sufficiently charged batteries when using Ni-MH batteries.
You also should set the correct battery type in the setup menu. So put in alkaline / NiMH or oxyride. According to what you are using.
Before you panic, buy a set of alkaline batteries, to make sure your camera is ok. Perhaps you are using rechagable batteries who are not ok anymore.
Nov 09, 2013 | Panasonic Lumix DMC-LZ7 Digital Camera
I need a manual for a fuji s2940
You may download a copy of the S2900-series manual here.
Jan 23, 2013 | FujiFilm FinePix S2940 14MP Digital Camera...
Manual for fuji s2940wm
If the lens isn't extending properly, try the procedures in this tip.
Sep 28, 2012 | FujiFilm FinePix S2940 18X Ultra Zoom 14MP...
Lines in pictures?
It could probably be the image sensor of your camera.
Aug 14, 2012 | FujiFilm FinePix S2940 18X Ultra Zoom 14MP...
Need help taking action pictures with fujifilm finepix s2940.. any idea on what setting should the dial be?
If you are getting bad results from the SRAuto mode, select the SP mode. Then press MENU/OK Use the Up/Down selector to highlight Scene Position. Select the Sport Scene Position (icon of person running). Then press MENU/OK to select. This will remain the default setting each time you use the SP mode until you change it again.
Jan 06, 2012 | FUJIFILM S2940 Digital Camera
Cameras Logo
146 people viewed this question
Top FUJIFILM Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Falling star
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
