SOURCE: Fujitsu air con fault (new system)
steve, first look at the manual if really it is stated in there that the three blinks indicates an o.u. pcb. second, do you install them yourselves?. im not sure regarding warranty if you install them. normally there should be a qualified installer to install it to cover warranty. again if you install them yourself, double check the wires that goes to the outside unit. make sure each wire goes to its corresponding location. any mis-wiring would may also indicate a 3 blink alarm. if its covered in warranty. they should shoulder the expense if it needs board replacement. i hope i was able to solve your problem.. tnx
SOURCE: indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at [email protected]
Thank you very much.
SOURCE: Outdoor unit does not start. indoor unit fan does run.
by the sound of it the relay in the outdoor section is bad
SOURCE: The timer light flashes twice about every 15 seconds
This may mean that the filters may need to be cleaned. According to service manual the unit has a "Serial reverse transfer
error at start up operation". Call fujitsu for service if the fault cannot be rectified.
I take the time to answer your questions, please rate me
Mat
SOURCE: fujitsu asya09lcc wallmount split lights flashing indoors
just happen to me, call the service guy........... he told me to cut power for 30 minutes cause it erase memory inside machine. I did and its working........ So happy
