SOURCE: Digital Audio Input
On many ht receivers you must enter setup mode and tell it which digital input you are using for each digital source. i.e. you can choose optical for the DVD input and coaxial for CD, and vice versa.
Good Luck,
BB
SOURCE: No audio from onkyo receiver
Press the input you want to use,eg sat, then press the digital input button on the front of the amp untill you get sound,then set amp to prologic 2.
Hope this helps.
CABLE GUY.
SOURCE: How to get non-hd DD or DTS sound from blue-ray on old receivers
It is not necessarily what features you have to look for, it is what connections you need to look for. Most blu ray players have the hdmi ports. On my blue ray I found it and it has the fiber optic end. I have used that and to me it sound just as good.
SOURCE: Onkyo TX-SR701 Digital audio port stopped working
you may want to try a factory reset by pressing and holding vcr1 button while pressing the power button. do this with the unit on. It will reset back to factory default. so any saved setting will be lost and you will have to set again to your settings.
SOURCE: How do I connect my
"R1" is not a unique model. Treat the Cable Box as the high-end source it is. Connect the highest quality audio to the unspecified Onkyo in accordance with its manual.
To avoid the cost and potential problems inherent in unnecessary cables, cable length and interconnects I recommend never running any audio or video signal to or through a component that can't use or IMPROVE it. Hence, in my rig, no video whatsoever goes to my AVR and no high end audio goes to my TV.
