SOURCE: Error message E08
You said you cleaned the player but did you clean the disc? Any scratches, dirt debris? To clean the disc you can but special cleaning soultions at various retailers. Have you tried playing diffrent discs, that will help rule out if it's the player or disc.
SOURCE: mp-c841(256mb) keeps giving a error--DISC
Make sure the hold switch is not engaged first - see p.15 of your manual for location.
Also, you may get that msg if you tried to load a DRM-protected file or an iTunes song (anything other than mp3 format is generally going to give you a problem with this player).
SOURCE: Philips Magnavox MWD200G DVD Player
I had a similar problem with my Yamaha DVD player which just kept displaying "reading, reading and reading"- eject-no disc or disc error. I took it into be repaired and was told it needed a new optical lense-cost $120.00 plus fitting.I was told not viable to fix. Not convinced I had a look on the internet and a suggestion given was to buy a can of Air Spray from **** Smith,$14.00 later and blowing the proverbial out of the inside of the unit-Bingo it works for about an hour and then, away we go again-reading reading reading - eject-no disc. Back to the internet and i found a DVD technician who advised the more often than not the problem is a dirty optical lense, and he has saved 100's from the grave by the following method. The most effective way to clean it is with a cotton wool bud soaked in Isopropyl Alcohol and give it a good rub without damaging it. I got the Isopropyl alcohol for $12.00 a 250 ml bottle from the local chemist and did what was suggested. IT WORKED and is still going- not sure for how long but the bonus is I can use the remainder for rubbing down my tired old body, as after shave or a refresher, in addition to fixing DVD's so not all is lost. It's worth a try considering I was going to throw the Yamaha away. Thanks to the internet and the good people who share their knowledge I am happy again.
Hopefully it will work for you. If not, don't forget the other uses for the alcohol.
SOURCE: whar does it mean when i get a message that say change engine oil
It means that the engine oil must be drained, the oil filter replaced and the light reset.
