Question about Refrigerators
Primo model 601141 leaking from cold water dispenser
Posted by Keri Mason on
Brad Goodale
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
Solenoid valve possibly leaking or faulty,you will need a tech to confirm this problem.
Posted on Nov 03, 2018
5 Related Answers
Anonymous
  • 146 Answers
SOURCE: water dispenser leak
I think I would think about getting a new one. It would cost more to fix it and then you may not get it back together so it wouldn't leak.
Posted on Dec 29, 2007
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Posted on Sep 07, 2008
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: built in water dispenser drips/leaks (fridge model
It is very possible that the water control valve on the rear of your refrigerator needs replaced. It would also be a good idea to install a pre-filter before the water gets to the water control valve. I believe the side of the valve that controls the water dispenser is stuck open slightly allowing water to drip. You can test by disconnecting the wires to the dispenser side and see if the drip stops. When you press dispense water the dual water control valve opens completely on the rear for the water to flow. If the seal inside is defective it will leak. Here are a couple places to finds the Dual Water control Valve
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Just enter your part number or model number or click on the photo on the second site listed. They are both good suppliers. Let me know if this is helpful or if you need more help Thanks, Sea Breeze
[email protected]
Posted on Aug 10, 2009
Anonymous
  • 65 Answers
SOURCE: water leaks from dispenser
Bad water filter or weak water inlet solenoid. Water line to back of fridge goes to inlet solenoid valve. Check it first. Would help to know the manufacture date. If it has a filter at bottom of fridge it will cause leaks and low pressure to dispenser if not changed each year.
Posted on Sep 11, 2009
Anonymous
SOURCE: Pelonis Hot & Cold Water Dispenser, water not cold
I too am having just room tempature water coming out of the cold
dispenser and I have had mine for 1 month.........
Posted on May 20, 2010
Tip
Wow this is awesome. I was getting so frustrated, but this completely fixed it....
We started getting a blinking light... indicating the jug needed replacement... after installing a full jug. The unit would cycle, then the red blinking light would come back on. Upon careful inspection of the feed tube and lines, it was realized that the plastic line on the intake of the pump body had been inadvertently pulled out just slightly (presumably from jostling the jug around during replacement). I believe that this breaks the seal the unit requires for suction, and caused the fault. I simply pushed the (white) plastic line back into pump body and heard an audible 'click'. Unit works fine now. I hope this helps, as these units are not exactly cheap.
on Apr 25, 2017 | Primo Grills And Smokers Primo Bottom Load...
Tip
PRIMO BOTTOM LOAD WATER DISPENSER, BLINKING LIGHT
on Oct 30, 2013 | Primo Grills And Smokers Primo Bottom Load...
Primo water cooler red light blinking
What do I do with my Primo water dispenser whenever the red light keeps flashing I have a full bottle of water in there but it just keeps flashing I can turn it off and turn it back on or I can push the button in the door and it'll go off within the next 20 minutes it will come back on and the water's cold and then the water goes to lukewarm
Nov 25, 2013 | Unknown Primo Deluxe Stainless Steel...
Where is the reset switch on a Primo water cooler model YL1136S
My Primo Model:YL1136S Hot Water Quit Working How Do I Repair It
Aug 24, 2012 | Baby Gear
Primo water cooler
I JUST BOUGHT A PRIMO BOTTOMLOADING WATER DISPENSER AND ITS BEEN ON ALL NIGHT AND THE WATER IS WARM. I LOOKED ON THE BACK TO SEE IF THERE WAS A WAY TO TURN IT UP BUT FOUND NOTHING. PLEASE TELL ME WHAT TO DO. [email protected] COMCAST.NET
Jan 06, 2012 | Primo 900172 1.0 Gallon Industrial Water...
Refrigerators Logo
318 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
