Question about Cycling
My chain is jumping and preventing me from free back spinning my pedaling.I was also told that my chain isn't catching properly when gears are changing..I don't know why..
Posted by Troy Mathis on
5 Related Answers
TireSideDown
  • 12 Answers
SOURCE: The chain wants to jump off while trying to change gears
There are several things that could be wrong:
Shifter out of adjustment
Chain worn
Chain and gear(s) worn
Shifter out of adjustment:
Try adjusting the cable tension by turning the barrel (the part between the cable and the shifter). Count the number of turns and reset it to its original position if this doesn't solve it.
Chain worn:
Chains wear out. hold a ruler up to it, with one end centered on a pin. 12" away, another pin should like up very very very close to the 12" mark. If not, it's probably worn out and needs to be replaced. No way around it. Some say chains are good for 500 miles only. Your mileage may vary. (keep reading...)
Chain worn and gear(s) worn:
If the bike has been ridden witha worn chain for a while, it will make the gears in the back wear faster too, and a new chain alone will not work. If this is the case, you need a new chain and new gears in the back. Often, gears in the back are replaced all at once in a 'cassette'. You'll have to make sure your front gears aren't worn out too!
Posted on Nov 20, 2008
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: Slipping gears on bicycle
Make sure the rear wheel axle is snugged up against he dropouts in the frame and that the wheel is centered in the brakes. Also, check the seating of the shifter cable at each end, but most likely at the rear shifter, to make sure the jacket is inside the ferrule.
Of course, it is impossible to get a sense for how well maintained the bike is. Perhaps the shifting problem's appearance is not related to the wheel removal and may be something else like bad cables or cable housing. The cable should slide easily in the housing. Shift the bike to its lowest (easiest) gears in front and in back. Then, without moving the crank, manually tug on the rear shifter cable from the rear and push it in. Resistance is bad. Sometimes a bit of lube inside the housing will buy you some time. Use something thin and squirt a little into the end then cycle the cable in and out to distribute it.
If you don't have a bike repair stand, find a small tree with a stout, narrow, low horizontal branch about shoulder height and hook the front of your seat on it so you can spin the cranks and test the shifting. If it's hard to downshift the rear (pulling cable into the housing) it will likely not freely shift upward because the only froce pulling the cable out is the little spring in the derailleur.
Shift to the highest (smallest) cog and sight along the axis of the it and the two rear derailleur pullies. They should all be in the same exact vertical alignment. If they're parallel but not aligned you can adjust the barrel on the cable at the derailleur. Try a small turn then shift up and down while turning the crank to get the cable and shifter to settle where the new adjustment wants to be.
If you ride regualrly it would be worthwhile to find a local bike shop (LBS) and get to know them. They can teach you some self sufficiency in exchange for a little business from you.
Posted on Apr 29, 2009
pippall
Philip Long
  • 1486 Answers
SOURCE: my audi tt quattro 2004 model yesterday stopped changing gears
Release bearing problem.Change the clutch Assembly
Posted on Jun 13, 2009
Anonymous
  • 484 Answers
SOURCE: problem with chain and gears
Wash, degrease and scrub the chain and derailleurs with a good degreaser (like Simple Green). Dry the chain and relubricate it with an appropriate bike chain lubricant (not oil or WD-40). Shift the derailleurs to the smallest chain ring and cog on the cassette (low front gear, high rear gear) and then loosen the cable at the derailleurs, pull the cables taut and reattach them. If the derailleurs still need adjustment, here is a procedure for it:
Flip the bike over (so you can pedal the bike manually while you shift) and shift the front to the middle chain ring. Shift the rear to the highest gear (small cog). Release the cable from the pinch bolt on the derailleur. Adjust the screw marked "H" on the derailleur until the jockey wheel on the derailleur is aligned perfectly over the small cassette cog. Set the cable adjuster on the derailleur to the middle of its range (find this by screwing it all the way in and then count how many revolutions it makes until it screws out completely. Screw it back in one half of the total revolutions). Reattach the cable and shift to the lowest gear (the biggest cog). Over-shift and hold on the shifter, then adjust the "L" screw on the derailleur until the jockey wheel sits just past the last cog. You have to hold the shifter to do this. Now shift into the middle gear (or one of the two middle gears if the bike has an even number of gears) and adjust the derailleur using the barrel adjuster you previously set to the middle of its range. Adjust it so that the derailleur is sitting perfectly over the appropriate gear. Shift up and down the cassette while pedaling and in every gear, reverse pedal (freewheel) to make sure the chain does not hop. Adjust as necessary until all gears are smooth.
Now the front:
Set the rear derailleur to the lowest gear (big cog) and the front to the lowest gear (small chain ring). Disconnect the derailleur cable. Screw in the adjuster for the cable tension all the way (this adjuster is on the shifter of a mountain bike or the down tube of a road bike). Pedal to make sure the chain is not rubbing on the derailleur cage. If it is, adjust the "L" setting on the derailleur until the chain moves by without touching the cage. Now pull taut and reattch the cable and shift the front to the big ring while pedaling. If it does not shift up well or completely, hold the shifter past its normal shift and adjust the "H" screw so that the derailleur allows the shift. Shift into the highest cassette gear and keep pedaling. The chain should not be touching the front derailleur's cage when you pedal. Adjust with the barrel adjuster until the chain moves freely without touching the derailleur cage.
That should be it, unless there is another mechanical problem causing the missed shifts, like a bent derailleur hanger or damaged teeth on the cassette cogs or a bad derailleur. If it is still problematic, come back for further information.
i hope this helps
-matthew
Posted on Oct 26, 2009
sisadsl
gavin jones
  • 1508 Answers
SOURCE: my 2005 r6 had all
It sounds a lot like 3rd gear and shift fork need replacing, it seems a very common problem on the r6, jumping to a higher rpm would mean it is jumping out of 3rd and back to 2nd.
There is a slight possibility the spring and ball, that locate the shift drum,isnt holding it in gear.
Posted on Apr 18, 2011
Shifting gears
when shifting gears on bikes you have to keep pedalling but with out load on the chain
shift one gear at a time as multiple gear selections may cause chain jump
do not pedal backwards as the selector is for forward motion only
Jul 25, 2015 | Cycling
The bike slips when peddle.
If the bike has gearing I would get your shifters checked to make sure everything is lined up properly and the shift points are set properly. if they are not it can cause the chain to drop off a gear only to shift back up on next rotation of the pedals.
Sep 16, 2014 | Cycling
Regardless of what gear it's in, my Zike Saber chain slips as I step on the pedals. How do I solve this?
the saber zike is a elliptical bicycle. All answers above think you have a motorcycle or they have no clue. Is the chain on the sprocket, It seems to be off the gear. Zike recomends switching 1 gear at a time. Do not go from 7th to first gear in one shift or chain will come off the gear .It happened to me .Chain id not easy to put back on as a bike, that you can turn upside down and have it support itself on the seat and handlebars. The saber you must hold the back wheel off the ground and try somehow to turn the peddle backwards. I am not sure how to make an elliptical chain go backwards like a bike does without resistance.
Feb 03, 2014 | Cars & Trucks
My 2005 r6 had all maintenance done chain and sprocket . new clutch and brakes but when i'm riding 3rd gear seams like the chain is slipping off then catching and when it catches it jumps to a high rpm ....
Apr 18, 2011 | 2005 Yamaha YZF-R6
Slipping gears
Your chain and drivetrain is probably worn out.
Read this...
http://www.sheldonbrown.com/chains.html
May 03, 2010 | Cycling
When pedaling the pedal slips when under pressure as if it has worn teeth and the chain is jumping i have the manual but is not clear 735ekg bike
If you have a bicycle with a deraleur system (chain with a lot of different-sized sprockets in the rear), is is possibly because the sprockets are worn combined with a slightly stretched (worn) chain. The best solution is to replace the offending sprockets (they are always the smaller ones) and the chain. You should be on your way. (Before doing ANY of that, however, MAKE SURE that your gears are adjusted properly. A deraleur that is trying to stay between gears will cause just this same symptom.)
Jan 04, 2010 | Cycling
When pedalling the chain turns without driving wheel
you need a new coaster in the back rim. theres little gears inside that grab when you pedal forward and not backward. you stripped/broke the gears inside. take the back wheel off and if the sproket/cog spins both ways then you need to have it replaced.
Oct 20, 2009 | Cycling
Chain not catching and noise
sounds like sand got into the chain, try spraying wd-40 well onto the chain then wiping the exccess
Jun 20, 2009 | Cycling
Cycling Logo
322 people viewed this question
Top Cycling Experts
Marvin
Marvin
MODERATOR Canada
MODERATOR Canada
Tom Chichester
Are you a Cycling Expert? Answer questions, earn points and help others
