Question about Hotpoint Dryers
Hotpoint Dryer Model HTDX100ED5WW: Not heating even though air is blowing and drum rotates.
From early on, this dryer would just "shut down" when a "normal sized" load was put in and the setting for heat was set to "Cottons/Regular" - the highest of three heat settings. After 15 minutes, I could restart it until it happened again, and again until the clothes were dry. Two remedies to this problem were to use the Wrinkle Free medium setting, which would take 2 - 3 times longer to dry each load, and pulling the entire dyer to the center of the small laundry room - thus extending the heat exhaust to about 4 feet (instead of the 12-18 inches direct to the outside vent). Research revealed this problem was normal for this model, so I just adapted as needed. Now, the dryer does no heat at any setting. The drum rotates and air circulates, but no heat. I have a service contract for labor only, but the service techs who they send always seem to diagnose that the parts needed to repair this dryer (and the past one) exceed the cost of the dryer itself (often with multiple parts and kits that have been unnecessary for the repair ... which has usually been a $15 part I could get at an electrical supply store). I suspect this is the same situation.
Posted by jbutkevich on
Fred Sops
    Sergeant:
  • 351 Answers
If it uses a pilot light check to see if it is lit. If no pilot the electric starter is probably bad. If no pilot does it make light buzzing as it is trying to start, if not the starter is bad.
Posted on Oct 31, 2018
5 Related Answers
Washer_tech
Geoff Siegel
  • 164 Answers
SOURCE: Maytag Atlantis MDG7600AWW Not Heating
the gas coils have a problem. as the dryer heats p the coils on the gas valve are failing causing the dryer not to heat. replace the coils and you should have no problem
Posted on Oct 23, 2007
Anonymous
  • 67 Answers
SOURCE: It takes several auto cycles on regular heat to dry a load of laundry when I think it should only take one. What's wrong?
first, check your exhaust, you have to make sure there is no buildup at all inside it. this is the most common problem to cause this. if lint gets backed up, there is a sensor that shuts down the heating element after only a few seconds. hope this helps
Posted on Oct 28, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Poorly heating clothes dryer
Best way to test the elements and stats is to disconnect each one in turn, and with your meter set on the ohms range ,test each one in turn for continuity, you should get F.S.D.(full scale deflection) on each component.
Another way to test the element, is to bypas the stats, and connect the 240v suplly directly to the element, it should get red hot, but do not leave it on for more than a few seconds..
If it had gone down to earth, then theoretically it should trip the circuit breaker.
Plz rate my solution.
Thanks.
Posted on Dec 25, 2008
Anonymous
SOURCE: DV448AEP sensor drying doesn't seem to work
I had the same problem with mine. My wrinkle free setting some how got turned off. As soon as I turned that back on machine kept running and dried the clothes fine.
Posted on Mar 28, 2009
Anonymous
  • 16 Answers
SOURCE: Kenmore 80 series (11076822690) doesn't stop running, with heat
its the timer
Posted on Jun 27, 2009
Why does my whirlpool senseon dryer start when i disconnect the thermistor wire but then shuts off after a minute?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Apr 08, 2015 | Whirlpool Dryers
My dryer heats but doesnt stop wben timer is set
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Sep 11, 2014 | Dryers
Will broken moisture sensor cause dryer not to heat
Aug 18, 2014 | Maytag Dryers
Whirlpool ggw9868kq .Ducts are clean, airflow is good. Drum rotates. Dryer warms up then heating stops. happens in both auto and timed cycles.
My whirlpool dryer Model GGW9896KQ2 seems to run ok but it doesn't seem to heat up properly and takes several cycles to dry clothes. I checked the exhaust vent and it seems to be blowing air out ok. Also, it appears the dryer goes to the cool down cycle way to early. In addition, the dryer will sometimes shut off before the time is acutally done. help--I don't want to spend money for a tech or even a new dryer. It's only 8 years old.
Aug 06, 2011 | Whirlpool GGW9868K Gas Dryer
The drum rotates and blows air, but it doesnt blow hot air. I already changed out the thermal fuse.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Dryers
Dryer runs, rotates, and air blows but does not blow hot air, therefore cloths will not dry.
heatman101
Apr 13, 2011 | Bosch Axxis WTA 3510 Electric Dryer
I have a hotpoint gas dryer that blows cold air not hot
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 08, 2010 | Hotpoint Dryers
Dryer drum won't rotate
if there is no air coming out of your vent on back of dryer then it would be likely your motor has gone out.
Jun 24, 2009 | Dryers
Dryers Logo
89 people viewed this question
Top Hotpoint Dryers Experts
peter gittos
peter gittos
Marvin
Marvin
Mike
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
