Question about Bushnell Cameras
Why does my bushnell trail camera only start taking pictures at 2300 hours when I cahang the card every morning at 10 am but it never takes a picture til2300 hours every time
I changed batteries but still doesn't take a picture til 2300 every night
Fred Sops
    Sergeant:
  • 351 Answers
Get manual it is programmed to start at that hour.
Posted on Oct 31, 2018
4 Related Answers
cena2fight
  • 3 Answers
SOURCE: Bushnell Trail camera won't store pictures
my trail camerawant take pictures
Posted on Jun 10, 2010
Ty Price
  • 11967 Answers
SOURCE: 11-9200 bushnell trail cam.
Sounds like you didn't use the "safely remove hardware" function when you took the card out of your computer.
Posted on Aug 03, 2010
Sajjad Inamdar
  • 661 Answers
SOURCE: my bushnell trail sentry wont
Hi grahamb457,
For you to save the pictures on the SD card, you should first select it as defauly memory from the setup options.
Once you select it as default memory you will be able to see the change in the number of photographs you can take on the LCD screen.
I would recommend you to restart your phone once you change this settings.
Hope this helps ...:)
Posted on Aug 28, 2011
Ronald Lockhart
  • 296 Answers
SOURCE: won't take night pictures
Two possibles: either the IR flash is bad,or the day/night sensor is bad.Unless you have parts from another M80,best bet is to try Moultrie support and send it in. However, they may tell you to buy another camera.
Posted on Dec 30, 2011
My model 119900 bushnell camera does not take pictures anymore. Is the a quick fix to the problem?
There are a hundred reasons why it won't take a picture....therefore, no quick fix. Someone with knowledge needs to examine the camera.
Oct 29, 2011 | Bushnell Trail Sentry 11-9200 Digital...
Trail Sentry 11-9200 Digital Camera: I bought this camera from a store that used it as ...
Bushnell recommends to only remove or insert cards with power off, or it can damage the SD card.
Borrow an SD card that fits in your camera and test it. If this solves the issue, buy a new SD Card here.
May 16, 2010 | Bushnell Trail Sentry 11-9200 Digital...
How do you delete pictures from a sd card used in a bushnell trail camera
The Bushenell Trail Sentry camera does not allow you to delete pictures from the camera itself. To delete those pictures, you need to take out the SD card from the camera and insert it to an SD card reader. Plug it into your computer's usb port and delete using Windows Explorer or any picture management application.
Should you have any questions, please don't hesitate to ask.
Nov 13, 2009 | Bushnell Trail Sentry 11-9200 Digital...
My memory card is in my camera, but when it takes a picture and i put my memory card in the computer to view the pics, there's nothing on the memory card. what's wrong
A few things... Make sure that the card is the one recommended for the camera. Can you play back a picture which you have taken? That needs to be checked first. Put the card in the camera, take a picture then view it on the camera's LCD. If you can see pictures, then some thing is wrong on the computer and the way it is reading the card.
Oct 21, 2009 | Bushnell Trail Sentry 11-9200 Digital...
Bushnell Trail Sentry Model 119320C Problem
maybe the deer are turning the the camera off.they are pretty smart .just kidding ,im a minnesota deer hunter,and i have downloaded the manual for this camera,and am currently looking for solutions,as far as formating the card ,you need to know what format first,then using your computer,right click on the card reader in my computer and you should see format,click on that and you should see options for fat 32,ntsc,if it uses other format,may need software,or possibly the camera has the capeability to do it ,still reading the manual,try a test with it in your yard after dark,and monotor it for a couple hours,maybe you will notice something
Oct 14, 2009 | Bushnell Trail Sentry 11-9200 Digital...
Wont take pictures
If every thing is working on the cam but the camera, and your cam has a built in memory, take the memory card out. Try using cam with just built in memory. Sometimes the cam wont format right with the memory card. Don't know why, but it just happens. If this works, you'll have to get another memory card. If the cam doesn't read the memory card, it will still work, but it won't take pictures.
Aug 30, 2009 | Bushnell Trail Scout 11-9500c Digital...
Make sure you have the day time set properly.  This means the time daylight begins.
Jul 04, 2008 | Bushnell Trail Scout 11-9830 Digital...
Cameras Logo
109 people viewed this question
Top Bushnell Cameras Experts
 Henri P
Henri P
Lee Hodgson
Lee Hodgson
Are you a Bushnell Camera Expert? Answer questions, earn points and help others
