Question about Miscellaneous
The department defaulted the placement, which resulted in me loosing a 4 months substitute post that i had got myself, what should i do now?
Posted by Sthabiso Gumede on
Fred Sops
    Sergeant:
  • 351 Answers
Go to human resources and file a complaint.
Posted on Oct 31, 2018
Substitute 4 and -4 for x in the equations y=x+1 and 2y-2=2x. Describe the results
y = x+1
y = (4) + 1
y = 5
y = x + 1
y = (-4) + 1
y = -3
2y - 2 = 2x
2y - 2 = 2 (4)
2y - 2 = 8
2y - 2 + 2 = 8 + 2
2y = 10
2y/2 = 10/2
y = 5
2y - 2 = 2(-4)
2y - 2 = -8
2y -2 + 2 = -8 + 2
2y = -6
2y / 2 = -6 /2
y = -3
The results are the same, implying that they are the same line.
Why?
2y - 2 = 2x
2y - 2 + 2 = 2x + 2
2y = 2x + 2
divide everything by 2
y = x + 1
Good luck,
Paul
Feb 07, 2017 | The Office Equipment & Supplies
Jennaire 8895aas panel out
Please check that model number again. I do not get any results with the number you posted.
Thank you!
Jan 24, 2013 | Jenn-Air Kitchen Ranges
Htc amaze camera freezes
Reset Phone Not a Solution _ Tested by Myself _ Reset Not Worked(4me) _then i tried to Wipe it out my htc amaze rom and installed it again _ but still its not working _ then i thought may be there is some hardware parts are moved or loosed from it place_ checked _ around 3 Times _and replaced all the parts Carefully but still not Fixed .. Guys u can try the last step but may b no result come to U_ So may b this case need a professional Help From the htc Department or any other Dev. Dept.
Jul 12, 2012 | HTC Amaze 4G Smartphone T-Mobile
Error three short beeps and three times
Most of the time this is a memory error code. Have you added new memory cards? Sometime the cards are not seated well, are the incorrect placement (cards need to be in pairs)
Check that and post your results. Good Luck.
C2Solutions
Nov 24, 2011 | IBM eServer xSeries x226
After assembling my bike myself, I cannot get the bike seat into it's aperture. It won't fit. even with the tightening mechanism completely loose. Any tips for logging it in place?
The manual for single speed bke is here...
http://www.huffy.com/Support/OwnersManuals.aspx
It's possible they supplied the wrong diameter seat post. It should slide in snugly. Don't force it.
You could call their Consumer Service Department 1.800.872.2453 to determine the cause of the problem.
Apr 27, 2011 | Huffy 26 in. Cranbrook Cruiser Bike
I want to to take a picture of myself on facebook but it just shows the manycamchat how do i get the acer crystal webcam back?
Please re-post your question under something computer related.
You posted under chainsaws so question comes to hardware department, and computer folks don't see it.
Mar 04, 2011 | Garden
Someone played with my phone an set lock code an i dont know it
I'm sorry to hear about your trouble ... I did the same thng to myself right after I got my first Cell ...
Default code is the last 4 digits of your phone number, normally.
Thanks for posting at FizYa.com
please vote
a
Nov 10, 2009 | Cell Phones
The spring placement for the trigger replacement
Look at the old trigger and see where the spring has been rubbing. Place the spring around the trigger post and slide it into the trigger housing. With help of a small screw driver or scribe to flip the trailing end of the spring over the stop post in the housing. Hope this helps
Sep 04, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Emachine battery won't take a charge
how long do you charge a battery for an emachine e525?
Mar 25, 2009 | Computers & Internet
The bobbin string gets tangled in a big mess and jams the machine
adjust the thread tightness. thread tension might be loose enough. be sure also the the bobbin inside the machine is place correctly! reversed placement would result in bigger mess.
Feb 26, 2008 | Brother XR-65t Mechanical Sewing Machine
Miscellaneous Logo
48 people viewed this question
Top Miscellaneous Experts
William Miller
William Miller
Dana Miller
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
