Question about Sharp Cell Phones
How to open blingking sharp using joy stick botton
Posted by Landz aguillon on
Sharp lc-24le155m blingking red lamp
Could be an open internal fuse or power supply failure
Apr 24, 2018 | Sharp Televison & Video
Did my regalcard register me on line
good pm sir ask ko lang what problem of sharp LED 24" model # LC-24LE155M blingking power light thank toy and god bleesed
Jan 29, 2017 | Office Equipment & Supplies
Loader stuck in down position, the joy stick will not raise or lower loader. The joy stick will work the tilt movme
didnt specify type of machine( generic answer)some machines have an electrical assist joy stick check switchs if hydraulic check the r check fluid level in the hydraulics the tilt uses less fluid to the piston than the lift arms ----check the hydro lines and connections doesnt happen all the time but try bleeding lift lines air or debris in lines
Sep 15, 2015 | Cars & Trucks
How do you fix joy stick on z760
This is a known error. The joy stick has a (or more than one) bad connection on the printed circuit board. In the long run all connections will be lost. Sometimes if you press the stick n a certain direction it works, but the error will become worse, till nothing works. If you don't have enough skills to repair electronic equipment, please don't try to do this yourself. The soldering, demands special skills, so you don't burn the circuit board, because it is very thin. I think on Ifixit, you can fine at least a similar Kodak camera, to see how to open and close the camera. Also special tools and skills are needed.If possible, bring it to a repair store and ask in advance what they will charge you for the repair. In the mean time, just use it to take pictures and use the stick a little as possible.
Oct 12, 2014 | Kodak Cameras
Push botton for sharp microwave sticks when you press it to open
Hold the latch in and spray some WD-40 penetrating fluid through top.
If this doesn't free it remove the phillips head screw under the bottom right forward corner and pull the control panel out from the bottom to access the latch
Jul 12, 2014 | Sharp Microwave Ovens
Hi When I boot it up , the acer emblem comes up then the screen goes black with a small cursor flashing in the top left hand corner
If you are having just a blingking cursor on boot up you must check if there is a disc inside the disc tray, or kindly check as well if there is a USB flash drive plug in on your computer and if there is any please remove them while your computer boots up as your computer might boot from it and it may cause just blingking cursor.
If there is no disc or USB flash drive installed, what you can try is to boot your computer in safemode and perform a system restore. Atleast restore back your computer 2 to 3 days back before this problem happen.
To perform safemode:
- turn off computer
- press the power the botton and after 2 sec tap F8 repeteadly until you see all the safemode options
- select safemode with networking/safemode use the arrow keys to highlight it then press enter
- computer will automatically boot into safemode desktop.
To perform system restore:
- click start > all programs > accessories > system tools > system restore
- click next then select desired date then follow the on screen instructions
- once system restore is done it will automatically restart and boot your computer in normal mode.
Cheers . . .
Mar 14, 2011 | Acer Aspire 5920-6727 Notebook
I have an air hogs sharpshooter helicopter and it wont stop spinning when i try to fly it and it only gets about a foot off the ground
it could be that you just need to use the adjustment nob it is next to the right joy stick u can turn it to make the heli fly straight. or one of your blades is not working like it should.
Jan 06, 2011 | Master Heaters Air Hogs Sharp Shooter...
How can i reset my samsung wa75b9 washingmashine. The green lights are flashing and dont want to anything.
1st thing to do press the child lock mode in 10secont until to remove blingking to your washing machine,the child lock botton is in the panel you see the small face of the baby,follow the arrow whre exactly the child lock some model are two btton you need to press some is one only, if this one is not stop blingking its means some of your part is worn out,especially the main board of the unit.ask the service center how much the coz of the parta and consider the buy new unit of your unit is old.
Dec 24, 2010 | Washing Machines
Joy stick
my mobile name is sony ericssion k750i it's do not work joy stick properly since 1 month pl solve this
Jul 14, 2008 | Sony Ericsson K750i Cellular Phone
Nokia 6600 joy stick problem
Open the phone..remove the joy stick & rotate it by 90 degree & insert it again.there r 4 points beneath it for 4 directions ,it is not sensing either one of them.otherwise u can replace the joystick from nokia care centre.
Oct 03, 2007 | Nokia 6600
Cell Phones Logo
Top Sharp Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a Sharp Cell Phone Expert? Answer questions, earn points and help others
