Question about LG Refrigerators
My lg refrigerator french doors the freezer part works but the top doesn't and the freezer part is showing up two lights and the refrigerator part isn't showing anything. any ideas what's going on?
Posted by Ashley on
Brad Goodale
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
You may have an airflow problem,suspect faulty fan motor.
Posted on Nov 03, 2018
5 Related Answers
Anonymous
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
22yooper
James Helmer
  • 828 Answers
SOURCE: LG LRFC25750 Refrigerator French Door
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
Posted on Jul 31, 2008
Anonymous
SOURCE: LG refrigerator NOISE
I have the sam eproblem...another site I went to said it is ice build up on the fan. Unplug the frig for an hour (don't open the doors or everything will spoil) and then plug in...it may defrost a bit and allow the fan to turn freely.
Posted on Sep 22, 2008
Anonymous
  • 65 Answers
SOURCE: Freezer door handle loose
u could always set the handle in place where it needs to be and use caulk or super glue to go around the handle and that should help it stay in place if that doesnt work the website www.amana.com to see if it has warranty for the broken handle good luck
Posted on May 26, 2009
Anonymous
SOURCE: how do I reset the lg water filter indicator light
i fixed the problem by asking my son. he has more patience than i and just held down the button longer and it worked.
Posted on Oct 15, 2009
I have lg french door refrigerator lfx21976st pull cold air but does not freeze in the freezer
Inspect back panel in the freezer section. Is it covered in frost?
Feb 01, 2015 | LG Refrigerators
How do I level my LG French door bottom freezer refrigerator.
There are screws on the front that raise and lower the wheels or the pads turn. If there is a kick panel below the door, take it off. You should see screws if it has rollers and if not look for pads that have nut shaped adjusters on the top.
Jun 24, 2014 | LG 7841 Bottom Freezer French Door...
Lg lfx25960st not cool enough
1. What are your controls (freezer & refer) set at?
LG recommends 0 deg for the freezer & 37 deg for the refer.
2. The way a modern refrigerator works is, the freezer is cooled directly and cold air then is blown into the refer section. The incoming vents in a French door LG are at the back, top. Return are at the bottom. Make certain that nothing is blocking these vents and than the refer has good air circulation.
3. Vacuum the coils at the back of the refer. A large build up of dust, dirt, animal hair etc. will affect efficiency.
Apr 14, 2014 | LG LFX25960 Bottom Freezer French Door...
Lights go off and on
your sensor sw is deff call for a tech to replaced
Jan 12, 2014 | LG LFD22860 Bottom Freezer French Door...
My lg fridge just stopped working no lights or power, the receptacle works and no breakers tripped
I have a similar manual that shows just what you are up against. How about the power cord itself? Is it ok?
FRENCH DOOR REPAIR MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 16, 2010 | LG LFC20760ST Stainless Steel Bottom...
How do I reset the lg water filter indicator light on the control panel of my lg lfx21971st bottom freezer french door refrigerator?
Oct 14, 2009 | LG LFX21971ST Stainless Steel Bottom...
LG French Door Refrigerator 3 door - Smoke out of Door Panel
Take out the freezer bins and look at the very rear of the freezer compartment. This is where your ice maker fan is. If it is caked with ice you have to defrost it. It's a pain, but it fixed my problem.
Mar 15, 2017 | LG LFC21760 Bottom Freezer French Door...
Refrigerators Logo
102 people viewed this question
Top LG Refrigerators Experts
Michael Thomas
Michael Thomas
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
