Question about Midland Radio Communications
I have a Midland gxt 1000. on the screen stay the letters rx and sounds like a radio without signal. As I can fix?
Posted by Juan Pablo Zengotita on
Eric Sutherland
    Master:
  • 665 Answers
3 Related Answers
Benimur
Louie Role
  • 6966 Answers
SOURCE: Midland gxt-850 gets HOT!
It is very possible that the terminal of the positive end of the bottom battery is shorting to the battery's body hence the heating up. If this is the case, then when you charge the radio, excessive current is flowing since the battery set has one shorted. Again this would cause heat buildup specially on the bottom battery and the charging terminals.
A possible solution is to check the bottom battery's positive terminal and ensure that it only contacts with the positive terminal of the battery and does not touch the battery body (which is negative).
Alternately (and perhaps more to your advantage), seek replacement of the defective unit considering it is new and therefore should be under warranty.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 06, 2007
Anonymous
  • 123 Answers
SOURCE: programming problem
http://www.midlandradio.com/owners_manuals.asp
Try this site
Good luck
Posted on Jan 23, 2009
thndr143
  • 141 Answers
SOURCE: my roadtrip cobra cb won't talk with my midland
The antenna on those roadtrip radio's are terrible, so make sure its mounted solid and screwed together tight. the connector that plugs into the side of the unit needs to be tight (may be broke inside)
Posted on Jan 30, 2010
Radio will not stay charged
It sounds to me that you have a defective battery. This can happen if a radio is left on charge or left uncharged for an extended period of time. I could be wrong but this is the most likely cause, especially if the battery is not a lithium one. They have this problem as well from time to time.
Dec 12, 2017 | Midland Radio Communications
I need the manual for the Midland gXt 1000.How can I download it?
Go here....
Owners Manuals
Select the model and when the pdf shows up, click the download icon in the upper right hand corner of the window.
Mar 15, 2015 | Midland GXT1000VP4 Two Way Radio
Midland radio manuals
Download your manual from here: http://www.manualslib.com/manual/103191/Midland-Gxt-850.html
Aug 12, 2014 | Midland Radio Communications
How do you change battery in Midland GTX450
Do you mean the GXT450 model, if so this manual is for the 300 upto the 450 and explains how to remove the batteries or battery pack.
http://www.manualslib.com/manual/103192/Midland-Gxt300.html?page=6#manual
Hope this helps
Jul 14, 2014 | HQRP Battery Replacement Fits Midland...
Wont turn on
did you try plugging it in. if its AC/DC try the other one to see if the switch is in the wrong position . May have a blown fuse also .
Dec 09, 2013 | Midland Radio Midland Gxt 1000 Vp4 Radio...
Hello and Good day, Can you please help me get the manual for the GXT 400 X-Tra Talk? Thanks Emileo
just click on this link.. its a pdf file....
www.buytwowayradios.com/Products/Midland/manuals/GXT-300om.pdf
Jun 22, 2010 | Midland X-TRA TALK GXT400 (7 Channels)...
Midland GXT 550 two way radio has a constant RX read out on display as though it is constantly receiving.
my 550 got wet wos leftout in the rain now after three mounths it shows a low battery
Dec 12, 2009 | Midland Two Way Radio
Radio Communications Logo
76 people viewed this question
Top Midland Radio Communications Experts
eradiostore
eradiostore
Michael Thomas
Michael Thomas
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
