My.canon ip2770 does not print. It blinks alternately green and orange.
Posted by Sophia lea on
Marvin
    Top Expert:
  • Office Equip... Master
  • 85,241 Answers
How to reset Canon Pixma iP2770/iP2772 error 5B00, follow instruction bellow;
1. Turn off printer
2. Press and hold RESET button
3. Press and hold POWER button.
4. Released RESET button, POWER still pressed
5. Press and released RESET button 5 times
6. Released POWER button
Now, printer on SERVICE MODE condition. In this condition, computer detect found new hardware.
7. When computer detect FOUND NEW HARDWARE, wait about 20 seconds and press CANCEL
8. Open software resetter Canon Pixma iP2770/iP2772 - download Re-setter Canon Pixma iP2770/iP2772
9. Set Destination - Region : select region - SET - OK
10. Load paper = 1 sheet
11. Clear Ink Counter - SET - OK
Wait, the printer will print D=000.0
12. Ink Absorber Counter - SET - OK
13. Reset iP2770/iP2772 is done, now turn off printer.
14. Turn on printer and try to print
Have problems when use software re-setter, read this Problems When Reset Canon Printer
15. When try to print, show up error message "The following ink may have run out",press and hold RESET button 7 seconds, then released them
Posted on Oct 30, 2018
5 Related Answers
Anonymous
SOURCE: Light Blinking
you to change printer exober
Posted on Mar 06, 2008
Anonymous
  • 30 Answers
SOURCE: Canon S300 printer. 7 orange blinks, 1 green. I
According to the manual found here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=330&modelid=6609
7 orange lights represents a bad print head, and the printer will need serviced or replacement. Since printers are so cheap lately, I would just go shopping. Hope this helps! Thanks!
Posted on Oct 21, 2009
Anonymous
  • 787 Answers
SOURCE: Canon 1560 error - orange light blinking 5 times
It's mean "Print head not installed/Defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number now is QY6-0064, because the old QY6-0042 is discontinued.
Posted on Oct 30, 2009
Anonymous
SOURCE: ip 1880. green and orange light blink alternately
try to reset ur printer. first off ur printer and take off the jack,just hold the grin light then plug the jack,and also hold the red light den move your fingers in the grin and red light
Posted on Mar 10, 2010
Anonymous
  • 37 Answers
SOURCE: ip 5300 error b200 10 blink orange-green
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Posted on Aug 02, 2010
Alternate blink green and orange canon ip2770
Ink absorber is full or waste ink pad is full. You need to reset your printer but you have to follow the procedure on how to enter the service mode.
2answers
How can i fix error 5200 on my canon pixma ip2770
You can try the following 1. Turn off printer, cable power still plug in,
2. Press Resume Button don't release
3. Press Power Button don't release and than release Resume Buttons
4. Press Resume Button 6X
5. Turn off printer cable power still plug in
6. Turn on printer again, now this printer ready to use.
Or try
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
7. And the computer will detect new hardware, just ignore ...
8. Press the POWER button, then the printer will die.
9. Press the POWER button again then the printer will flash and ... IP2770 Printer is ready to use
19helpful
3answers
Canon ip2770 error 5100 and 5200
How to Reset Canon IP2770 Error 5100:
Error 5100 means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps.
Turn off printer
Remove both the cartridges from the printer
Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
Return the cartridges
Turn on the printer.
Error will be removed
How to Reset Canon IP2770 Error 5200:
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (Do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
9. Press the POWER button again then the printer will flash and ... IP2770 Printer is ready for use.
Other Ways Reset Canon iP2770 error 5200:
1. Turn the printer, and printer will look normal.
2. Run the printer for printing documents or print test, then the 5200 error will appear.
3. Jump unplug the power cord without pressing the on-off
4. Open it and slide it into the middle catridgenya manually (press the white penguncinya hook behind the head, for cartridge can be pulled into the middle)
5. Unplug all cartridges and leave the lid remains open
6. Turn the printer, hit the head will move left and right because the lid was still open and will stop in the middle.
7. Replace the cartridge, and close the correct
8. Your printer will return to normal. (Source: from all existing sources)
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
7helpful
I have a canon printer IP 2770 .....i try to one my documents and shows that error 5200... what does it mean
Here's How to Reset Canon IP2770 Error 5200:
Print head stuck on the right hand side and lamp is flashing alternate green and orange
Found this today (and it worked):
canon waste tank reset for canon i70
Below is a procedure that in most cases should resolve a Canon i70 waste tank issue
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
(Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button.
(Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
*** 4 times Green Waste ink counter resetting Both the main and borderless print waste ink counters are cleared.
Canon i70 InkJet Photo Printer
28helpful
2answers
IP2770 EROR B200
If your all cartidge is not fully loaded on ink than showing the error.
6helpful
ERROR 5B00 IP2770
How to Reset printer canon ip2770 (E 5B00) ip2770.jpegIP2770 Resetter v1074 I have tried. IP2770 Resetter was sent by our friends in Jambi, and hopefully this iP2770 Resetter runs perfectly. Resetter is free passwords ... and FREE
How to Reset Canon IP2770 Error 5B00
Download Canon iP2770 Restter v1074 free pass Here
(Do not forget to turn off the download manager, for a successful download)
Go to the iP2770 Service Mode:
V1074 iP2770 Resetter Then run it:
1. Prepare 2 blank paper in the printer
2. In the menu "Clear Ink Counter" click "Play" and "Platen"
3. Click Test Print ... Done ...
(In some experiments sometimes "platen" unable / err message appears, but no problem, still can work well)
Hopefully Successfully
112helpful
4answers
2helpful
My Canon pixma ip 4000 won´t print. The light at the turn on button blinks five times orange and then comes one green blink. I have tried to clean the print head but that didn´t change anything....
this indicates a the print head is not installed correctly or is faulty.
if the green and orange is alternating 5 times then it is caused by the sheet feeder.
1helpful
Canon pixma ip 3000 error message printer is offline
If the orange lamp blinking only it's the print head is not installed, or it is not properly installed.Open the cover remove the print cartridges then remove the print head and put back it on.If not help the print head is defective and need replace.
If the orange lamp blinking with green alternately it's ASF (cam) sensor error.The problem is in sheet feed unit.
Marvin
Marvin
