Question about Plumbing
Price phister faucet has a pull down sprayer with on/off toggle on the back. Looks like cover is missing. Just bought this house. prefer to repair the pull down piece, rather than have to buy new.
Posted by Joan Donnelly on
Fred Sops
    Sergeant:
  • 351 Answers
Go to Pfister web site qand ask for parts for Pfister, keep model number handy.
Posted on Oct 31, 2018
5 Related Answers
James Chandler
  • 686 Answers
SOURCE: KITCHEN FAUCET (single handle PRICE Phister ) suddenly quit flow
Take it apart and clean out calcium lime or rust build-up. Also check to be sure your shut-offs are clear and running well
Posted on Jan 09, 2009
Anonymous
  • 3 Answers
SOURCE: Price Pfister kitchen faucet two handle with
It may also be a missing weight on the sprayer hose, or that the sprayer hose is obstructed. Open up the cabinet under the sink and look a half-loop of the sprayer hose that should be hanging down from the underside of the faucet. It must be able to descend without obstruction as you return the sprayer to the body of the faucet. If it is resting on a box of dishwashing soap or otherwise obstructed, then it doesn't have it's full weight to counterbalance the weight of the sprayer head. Capice? It needs the weight of the hose to 'weight it down'. Also, there should be a donut-shaped weight around the hose that should be able to freely slide to tha lowest position of the half-loop as the sprayer is extended and returned. Make sure that's working too.
Posted on Apr 04, 2009
clay
  • 74 Answers
SOURCE: price phister marielle kitchen faucet is leaking
Take the faucet back to where it was purchased as I believe PF has a lifetime warranty on their products.
Posted on May 03, 2009
snap101
snap101
  • 117 Answers
SOURCE: grohe sprayer faucet will not retract, spring around hose below.
check out the spring on the hose under the sink, sometimes they come loose on one end and they lose their spring back into the faucet
Posted on Aug 01, 2009
Dan Damron
  • 39 Answers
SOURCE: kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
Posted on Aug 04, 2009
The sprayer attachment to my kitchen faucet must have lost a spring or something. There is no give to the handle that i used to be able to push on, it simply stays down and the water will only flow threw...
ya you are correct, unfortunately there is no repair for this. Here is the link to see the parts which make up your faucet and to buy them. if you need anything else just ask:)
Jul 26, 2011 | Price Pfister 532-7PCC Marielle Pull-Out...
The waterline came loose from my the pullout sprayer and fell into faucet housing and i can t push it pack through the housing so I can reconnect it.
most of these sprayers have a compression fitting
for attaching if it gets bent or twisted you must
replace with new fittings or new sprayer
Oct 31, 2009 | Moen 7437 Chateau Single Hole Kitchen...
Why do I have low pressure on sprayer and still have water coming out of faucet when I am spraying.
Get the replacement parts in about 10 days FREE from PP. Call 800-732-8238. The flow is the diverter tee. I had the cartridge and aerator replaced. And then I replaced the diverter tee. I ordered the parts on a Saturday; got them the following Saturday. Below is a video to remove the diverter tee. The video is helpful, but doesn't tell you about the other 2 connections. The "spout" connection and the connection to the right (the "t" part) is simply a wiggle off. Then after those are off (with lots of water coming out - get towels ready), then you can crawl back from under the sink and get the sprayer off. The sprayer procedure is in the video (push up/in hose) then pull down gray collett. These faucets were discontinued in 2005; a plastic disconnect is now available for newer models. Also, we had to replace the cartridge and the aerator to keep it from leaking out of the handle. The problem we originally had was not having equal pressure with the faucet and the sprayer. The faucet would be running and then the pressure would go down. The sprayer would be weak when the faucet was on - never getting full pressure from the sprayer, just a trickle. It was "moody."
26 Series:
Removing Diverter/Quick Connect:
Dear Customer,
Thank you for contacting Price Pfister, here is a link to a video that will guide you through the steps on how to either remove the quick connect or the diverter.
http://www.pricepfister.com/about/diverter.aspx
You can go to PP's website and see and "Exploded View" of the model you have. If in the model number it states "XX" that is the finish - for example, mine states Marielle Kitchen Faucet "26-3NXX" The "3" is the number of holes (put a 4 in its place for 4 holes). The XX is SS for Stainless steel - even though it's chrome.
Oct 29, 2009 | Price Pfister Marielle Kitchen Faucet with...
Replaing sprayer
The Price Pfister web site has a video showing you how to disconnect the hose. Basically, you have to push the hose end into the junction block and then grasp the gray plastic fitting, pull the fitting, NOT the hose, away from the junction block. This sounds good in theory, but when upside down with your hands stuck in a small crevase under the sink, it can be a real challenge. Go to the Price Phister web site and watch the video. Good luck.
Rick120977
Oct 05, 2009 | Price Pfister Marielle Kitchen Faucet with...
Kitchen faucet leaking pull down sprayer spout type
May 04, 2009 | Price Pfister J103-BC 100 Series Kitchen...
Price Pfister kitchen faucet two handle with gooseneck and pull down spray. The pull down sprayer will not stay up in the goosneck.
Feb 19, 2009 | Price Pfister Plumbing
My price pfister bathroom faucet wont shut off.
you may need a new fucet...the manifold opening for the cold has probably craked or split
contct price Pfisterrdirectly they may send you a new faucet
Price Phister is more about looks than function they want to keep their marketing sales
when I built my house I ut rice phister in because of the looks ..function was marginal
Jan 30, 2009 | Price Pfister Marielle Kitchen Faucet with...
Jan 09, 2009 | Price Pfister Marielle Kitchen Faucet with...
Plumbing Logo
276 people viewed this question
Top Plumbing Experts
Bill Johnson
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
