Question about Daewoo Refrigerators
My Daewoo FRS-U201A1 ..the freezer works great from the middle down but bread on the top doesn't freeze..I was told it is the special pump?..any help
Posted by Janine Rees-Denman on
Brad Goodale
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
I think you may have a slow refrigerant leak it will only get worst,runing the fridge is wasting power,time for a new fridge.
Posted on Nov 03, 2018
5 Related Answers
Tony Coultrip
  • 183 Answers
SOURCE: need help
With this model it suffers with the evaporator freezing up, try to defrost overnight with the doors open, restart the following day and it should start to work ok within 24hrs. Regards Advisor
Posted on Sep 01, 2007
22yooper
James Helmer
  • 828 Answers
SOURCE: Freezer cold but not freezing
Check the settings for the freezer control. Refrigerator temperature control normally controls the run time of the compressor. if the freezer control is set to low the refrigerator temperature will be fine and the freezer will be warmer. Setting the freezer control to a colder setting will hold back more cold air in the freezer and reduce the air volume supplied to the refrigerator. Check and make sure the condenser coil is clean.
Posted on Jun 08, 2008
Anonymous
SOURCE: Daewoo FRS-2031IAL instruction manual
Hold down the [ice make lock] and then the [lock] button simultaneously for 3 seconds. It took me a couple of attempts but I got there in the end (the manual mentions holding them down at the same time).
Posted on Apr 21, 2009
Anonymous
SOURCE: Daewoo FRS U20 DAi side by side f/f fridge
MIne has the same problem, the insulation is breaking down and cannot be repaired.
Posted on Jan 14, 2011
baraquielnar
LEONARDO BARAQUIEL
  • 247 Answers
SOURCE: My Daewoo FRS-2021IAL fridge/freezer control
try to re insert the ribbon connector on your PCB board possible loose connection then reset your unit to unplug your unit for a few minutes the n plug on after then observe the operation.
Posted on Mar 06, 2011
Testimonial: "Thankyou. I tried that with all the connectors, with no joy. Tonight the control panel light kept coming on for no reason. ??"
Ice maker problem daewoo frs-2031 IAL
I wouldn't buy a Daewoo fridge with Donald Trump's money!
Jun 27, 2016 | Daewoo Freezers
My freezer only freezes certain food. All the
Get a freezer thermometer and ensure the temp is turned down to between 0 and 10 degrees F.
Oct 05, 2014 | Refrigerators
Why isnt the top part of my Daewoo FRS-U20BG larder fridge/freezer working although rest of freezer seems ok?
Is it just the freezer section? Open the freezer door for a minute and then, without shutting it, press the button on the inside that makes the light go out. The fan at the back at the top of the freezer should start whirring. This circulates the freezing air. If it doesn't start then that's your problem as the freezing air isn't getting to the top of the freezer. It's simple enough to replace. Buy a new part (30 pounds?) and replace from the inside by removing the back panels to the freezer. Turn the freezer off and unplug first though, obviously! Hope this helps.
Jun 16, 2014 | Daewoo FRSU20IA Freezer
Daewoo frs-U2OIC top shelf freezer not freezing
Could be the internal fan at the top of the compartment or its electrical feed is not working. With the door open, hold the light switch in (the fan usually doesn't work when the door is open) and see if it is spinning. If not, it and its connections should be checked
Feb 13, 2012 | Daewoo FRSU20IC (21.8 cu. ft.) Side by...
Just bought DAEWOO FRS-U20DC,cannot get ice maker
how do i suse my model 230 gps
Aug 27, 2009 | Freezers
Fan is a big issue. New problem though.
good day!first and foremost, in most freezers, the highest freezing point is 7.in regards with the water dripping from the air vent hole, you have to minimize your your freezing setting to the middle.turn it to 3 or 4 freezing point.
Aug 22, 2008 | Haier HTE21WAAWW Top Freezer Refrigerator
Need help
Jul 14, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top Daewoo Refrigerators Experts
Lawrence Oravetz
NOEL
NOEL
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
