Question about Nortel Lands Phones
I have a Nortel Networks M3904. I need to unlock voicemail because I can't remember my new password I set. We do not have the Admin phone to go to. Can you tell me what I need to do?
Posted by Denise Godwin on
Argospete
    Genius:
  • 1,035 Answers
Might be best if you reset password. go to your email web site and log in. email address fine, then look for small question forgotten password.
complete with your email address, if recorded with email website it will send you a link or offer to alter change password. if lucky then remember to save password to pc memory. you can then look up in settings passwords in fact try that first go to settings and general then passwords
if logged you should get code to open if you haven't altered try 0000 bevlucky will let you in then sift through other passwords to find your. then edit change AND REMEMBER. GOODLUCK.
Posted on Oct 30, 2018
5 Related Answers
Anonymous
SOURCE: How to change time on my T7316E Nortel phone
Step 1
Press the FEATURE key followed by **8463
Password Retry Step 2
Press 266344 on the dial pad buttons to enter the DEFAULT password. Your password MAY BE DIFFERENT! The display will show the following options:
Hour: 01 Next Change Step 3
Select CHANGE - the display will show the following options:
Hour: __ Cancl Step 4
Use the dial pad buttons to enter the hour. You must use two digits for all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM or PM. Select CHANGE and OK to choose PM. AM OK Change Step 5
After you have entered the hours, select NEXT. The display will show minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the RELEASE (RLS) button to end your session. The time will be changed and the date will remain the same.
If you want to change the date, select NEXT.
Minutes: 00 Next Change Step 6
The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005).
Select NEXT, and repeat to change the month and the day.
Year: 99 Next Change Step 7
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
Posted on Mar 12, 2009
ynotphone
ynotphone
  • 192 Answers
SOURCE: We have Nortel T7316. I have been locked out of
How do I reset a password on a Norstar Voice Mail mailbox?
Press Feature 983.
Enter the System Coordinator's Mailbox number (default is 12, 102, 1002, depending on length of extension numbers) followed by Password (default 0000).
Press MBOX.
Press CHNG.
Enter the mailbox number that is giving you troubles.
Press RESET. The password has been reset to default (0000).
Good Luck.
Posted on Sep 04, 2009
consultel1
george peters
  • 860 Answers
SOURCE: How do we reset a voicemail password for a Nortel
press feature 983 the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
press the Rls key
your password should be reset to 0000
Posted on Oct 20, 2009
consultel1
george peters
  • 860 Answers
SOURCE: I am locked out of
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000.
Posted on Dec 11, 2009
Testimonial: "OMG THANKS SO MUCH!!!!!!!!!!!!!! YOU FIXED IT!!!! THANK YOU THANK YOU!"
SOURCE: unlock Nortel t7316e voice mail.
Reset the voice-mail password.
Do so by first pressing
Function 985 (to view the mailbox number the phone is using)
Function 983
Log: 1020000 (or 120000, 10020000 1st is for 2 digit extensions 2nd is for 4 digit extensions)
Left Button (MBOX)
Right Button (CHG)
Enter Extension
Left Button (RESET)
This should reset the password to 0000, the steps maybe a little bit off depending on the software version installed on the phone system.
Posted on Feb 25, 2011
Not the normal voicemail problems
Before you can do anything you need a M7310. Programming a Nortel voice mail requires M7310. It uses the 3 soft keys under the display to program it. You can get one cheap on EBAY. Next you need to find out what type of Voice Mail System in connected to your Nortel phone system. Below is a link to a Older StarTalk manual. You may have a StarTalk, StarTalk Flash, or a Call Pilot.
http://www.myuserguides.com/Nortel_Norstar_Startalk.pdf#page=15&zoom=auto,-69,407
Below is a link that tells how to reset the System Manager Password.
Reset Admin Password Norstar Meridian and Nortel BCM Help Guides
The default code and password for System Admin is F983 and 1020000 or 1021111. The photo below shows a system admin programming tree. Hope this helps
Charlie
Apr 10, 2015 | Nortel Norstar M7208 Telephone
How do I set up a voice mail with a Nortel M3904?
This is dependent on you being able to access your voicemail mailbox (a mailbox has been setup for you by the administrator and you know the codes to login to your mailbox). Go to your voicemail which should be:
  1. press the message key.
  2. Enter your mailbox number, then press #
  3. Enter your password, then press #. (if you don't know this then you will have to contact the administrator for the telephone system)
When logged into this:
  1. press 82.
  2. Press 1 for external greeting, 2 for internal greeting, 3 for temporary greeting, or 9 for Personal Verification (spoken name)
  3. Press 5 to record then wait for tone.
  4. Press # to end recording
  5. Press 2 to listen to the greeting
  6. Press 76 then 5 to delete the greeting and re-record it.
  7. Press 4 to return to your messages.
Nov 24, 2014 | Nortel Networks Meridian M3904 Corded...
How to unlock the nortel T7100 phone
What is it that needs unlocking?
In other words what can you not do?
You have a business phone therefore your office admin should be notified of issues and/or a tech called.
Oct 20, 2012 | Nortel Networks T7100 Corded Phone
Auto attendent voicemail locked
Go to this phone press feature 983 this takes you to admin change mail box .The general mbox is 100 this is the mbox you want to change
Oct 09, 2009 | NorStar M7324 Telephone
My nortel voicemail is locked
What password is no longer valid? The admin, the operator, the installer?
What are you pressing to log in?
Jul 07, 2009 | Nortel Business Series Terminal T7208 -...
Nortel T7316e help
dial your voicemail, put in your password, after you are in the voicemail, press 8 and listen to the prompts, it will tell you were to record your name for the company directory.
Jun 26, 2009 | Nortel T7316E 2-Line Corded Phone
How do i set up a voice mail greeting on my nortel phone?
bodell,
The short version of getting to your greeting is:
Feature 981 or open voicemail key
your password
"8"for admin
"2" for greetings
"1" for record
"1" for primary greeting
"'1" to record your greeting
at the tone record your greeting
"#" to end recording
after you record press 1 to listen 2 to retry or # to accept
press "rls" key when finished
hope that helped.
Jan 15, 2009 | NorStar T7316E Corded Phone
Lands Phones Logo
315 people viewed this question
Top Nortel Lands Phones Experts
martin hogg
pbxinc
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
