Question about RCA Audio Players & Recorders
On off light is on. No response from any buttons. SPS 3600 RCA undercounter cd radio player
Marvin
    Top Expert:
  • RCA Master
  • 85,239 Answers
Time for a new player, these are not repaired.
Posted on Oct 30, 2018
5 Related Answers
Anonymous
  • 108 Answers
SOURCE: CD player will not play CDs
1.Check whether your cd s are good and readable
2.then the problem with the cd player laser beam reading assembly and its associating blocks
3. i guess your cd player laser beam lens is too weak or dead.
4. There is possible to change the lens system with a new one
5.Contact service centre for further rectification
Posted on Dec 22, 2007
sewell94
SOURCE: GES050 undercounter radio/cd player
..just read about your reception/interference problems and, having lived through similar situations for some time — particularly with different weather conditions. The following solution has settled it all : wrap power cable around storage brackets at back of radio with a short length then wound around support posts (between radio and cupboard from which radio hangs), then run short length to power supply outlet. In my case this result comes after much experimentation with the length of unwapped power cord (including fully unwrapped and stretched out) and different patterns of winding around the support posts. This final result takes care of everything (better sound, no interference/loss-of-reception when moving around in the room or in front of the radio, weather has no effect, stations received that could not be before due to overlap by nearby, more powerful ones). I have only about 2 1/2 feet of cable running from the brackets at back of radio, then wound once around center support and half around right support to then go to wall and down to receptacle close by (I tried all kinds of combinations of unwrapped lengths and winding patterns around 1 to 3 posts)...individual cases may be different. so GOOD LUCK, 'cause the radio is great...!
Posted on Aug 07, 2008
Anonymous
  • 448 Answers
SOURCE: I recently received a trutech
Recently received.......warranty status?
Posted on Jan 06, 2009
Anonymous
  • 59 Answers
SOURCE: 6-Disc CD Changer is not working
Unfortunately most times with these 6-disc systems once it quits working it is usually time for a new unit. The manufacturers all reccomend reprogramming the radio, but this rarely does anything other than waste your time and money. Go for the new radio.
Posted on Mar 15, 2009
ABRsvcs
  • 4234 Answers
SOURCE: My RCA RCD160 Radio/CD playder will not play CDs.
Try cleaning the lens in the CD player with a cotton swab and alcohol. If that does not resolve the problem, it is likely that the optics are defective and need to be replaced.
Dan
Posted on Mar 25, 2009
Change radio from am to fm
To change between AM and FM push the BAND RADIO ON button on the radio or the remote. Here is a link that will allow you to view or print the manual for your radio:
http://static.fixya.com/Manuals/G/GE/75295_Clck_R_4FB4DC9750E55A3910C4BE1CD2294289.pdf
Nov 30, 2009 | GE 7-5295 Undercounter DC /Radio Combo -...
Clock Setting
Press SET to enter time setting mode. Use the TRACK/SEARCH/TUNE buttons to select the correct time. Press SET to save clock time.
Mar 09, 2009 | GE 7-5295 Undercounter DC /Radio Combo -...
RCA RP5640 CD player failure
I too have recently found out that the cd portion of this radio was making strange noises. When i would press the open/close button, it would not open. I read your article and you mentioned you could not find the company mentioned. I did a reverse search on the address and came up with 5 different companies at the same address, neither of them being called "Vernurer Electronics" but other audio services. If you go to "whitepages.com" and click on the tab " reverse search" enter the address and you will see what i mean. I haven't found a solution to the cd door not opening but i'm still searching.
Sep 19, 2008 | RCA CD Player/Clock Radio (RP5640)
Setting the time on my clock on radio Model # RP3755B
Well, I have an RCA clock radio/CD player and just figured it out. Press the "Time" button and hold it down while pressing the CD "Forward" button. Hope it works for you! Ron
Jul 03, 2008 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Alarm
Reboot the machine, including taking out the batteries. Don't know what causes it, but that's the only way mine stopped, and I'm never touching the Timer button again, because I think that's what got the problem started.
Oct 26, 2007 | GE 7-5295 Undercounter DC /Radio Combo -...
Top RCA Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
