Have head open, power up, wait for message Head open, close head, wait for message Printer paused. press pause button get one line or the beginning of the calibration then get message Shutting down. usb to windows 10 system, using Bartender but software not running
SOURCE: Zebra 4M Plus Pauses unexpectedly
try to run the manual calibratio from the setings.
run "manual calibration"
move the ribbon out from the sensor (with the print head open) and take out 3 or 4 labels from the rollar and put that blank label paper unther the sensors on the left,
say "ok"
wen appear "reload all"
put the ribbon and the normal labels on the correct possition, and say "ok"
try to run sext the sensor profile.
save data (twice on "setup button")
tur off, and on again.
SOURCE: pause and error light will not go out
The only fix is to replace the logic bd.
I have plenty of them in stock and can repair them if needed.
Please contact me for pricing.
Thanks
Rory Cardenas
Midrange Repair and Parts
3821 W. 127th Place
Alsip IL 60803
708-597-4222 x240
[email protected]
AOL IM: RORYMRP
SOURCE: lq2180 when print few lines, the printer pause
its may be heaving problem with the control panel clean replace the buttons or replace the control panel and check it ................
SOURCE: I turn on the zebra
1.Double check that the ribbon and the labels are routed correctly. 2.Make sure the media guide is holding the labels against the inside of the printer and not moving to the right away from the media sensor. If the labels are sliding to the right as they come out, increase the left side head pressure on top with a flat blade screw driver. Download the user manual at zebra.com .Check the media type and sensor type, and set for thermal transfer if using a ribbon.
