Question about Bunn Coffee Makers & Espresso Machines
Why does my bunn coffee maker leak from the bottom when i add water
Posted by larry ludwig on
Marks concession repair
    Habit-Forming:
    New Friend:
  • 76 Answers
It could be so much lime build up that the water going in is too much for the water to come out so it will leak out the top from the thermostat hole plug and or the water pan is flowing over the top cus no place else to go?
Posted on Apr 27, 2019
5 Related Answers
Anonymous
SOURCE: my bunn coffee maker leaks
You need to replace the washer kit inside the top of the maker. Remove the 3 screws that fasten the top and lift it off. You will see the rocker leaver that allows the water to flow into the tank. At the point where the rocker stops the water there is a series of washers that degrade from the heat over time and allows the leak. The washers are very easy to replace. The problem is finding the washer kit. I found it at: www.buyitnow64.com for $3.95 plus shipping (FedEx is only $9.98). I bought 2 (one for backup) kits.The original washers lasted almost 6 years. I had repaired this problem before with a washer from my shop but it broke down rather quickly from the direct heat from the tank. This washer kit is a Bunn washer kit that is supposed to fit all Bunn machines both residential and commercial.
Hope this helps. It took me 2 hours on line to find the washers!
Posted on Dec 11, 2008
Gord Thurston
  • 131 Answers
SOURCE: Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Posted on Feb 13, 2009
Anonymous
SOURCE: MY BUNN COFFEE MAKER LEAKES WATER
Yes Bunn will send you a repair kit free of charge. Just apply a bead of silicon below the rubber gasket before you tighten it down and it will solve the problem.
Posted on Mar 16, 2009
atbsmmom
  • 189 Answers
SOURCE: I have a bunn coffee maker the NHBX is the # it is
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
Posted on May 19, 2010
atbsmmom
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
My bunn coffee maker is leaking water out of the
Please get the model and code date located on the bottom of the brewer. The machine has a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, it will be replaced at a discounted price. Once you have this information please call customer service.
Oct 24, 2009 | Bunn NHB Coffee Maker
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
I have a GRXB bunn 900 watt 10 cup coffee maker that leaks from the bottom when you add water. can you help me find the problem
If sounds like a bad seal/gasket. Please call customer service with the model and date code. If your machine is 3 years old or less, it will be replaced at no cost. If it is over 3 years, depending on the date code, there is a seal kit available to repair the leak. Or we can replace it at a reduced price.
Oct 01, 2009 | Bunn 10 Cup Home Coffee Brewer
Leaking a half cup of water from the bottom while brewing
Call bunn for replacement gasket free of charge per recall.
Jul 13, 2009 | Bunn 10 Cup Home Coffee Brewer
Apr 29, 2009 | Bunn 10 Cup Home Coffee Brewer
Jan 12, 2009 | Bunn VPR Coffee Maker
Bunn Coffee maker
your problem is caused by the pour-in tray leaking where it mounts to the tank. There should be 2 screws under the pour-in lid, and a third toward the rear of the brewer. if you take them out & lift up carefully, you can see the pour-in tray. in the bottom of the tray, there is a bolt that mounts the tray to the tank. If you remove that, you can lift the pour-in tray out. Be careful, as these trays get brittle over time, and are prone to cracking.
Sep 05, 2008 | Bunn NHB Coffee Maker
Coffee Makers & Espresso Machines Logo
2,380 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
