Question about JVC Car Audio & Video
I have a 94 Dakota and I need to find out what wires go where and the same for jvc radio
Posted by Elizabeth Oxford on
  • Alphanso Tee Feb 19, 2019
    Hi Elizabeth Oxford, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? what model wiring varies by model
2 Related Answers
Anonymous
  • 160 Answers
SOURCE: 94 chrysler lebaron radio wire diagram
GO HERE:
http://www.wirediagram.com/chrysler.htm
TO FIND UR CAR AND THEN THE PROPER DIAGRAM.
Posted on Dec 15, 2009
Molson02536
Harvey N Tawatao
  • 3854 Answers
SOURCE: radio wiring diagram for 94 dodge dakota
1994 Dodge Dakota Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/Blue
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Black/Yellow
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Blue/Orange
Right Front Speaker Positive Wire (+): Violet/White
Right Front Speaker Negative Wire (-): Brown/Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Red
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Red
This should help and thank you for using Fixya.
Posted on Mar 06, 2010
Testimonial: "just what i was wanting thanks a bunch"
Which wires do I use for the acc/battery on Dodge Dakota for Radio
One wire stays hot all the time (yellow) and acc is only hot when the key is on. you should be able to find the wires in the original wire harness to the old radio with a test light or a meter.
I have an ford explore 94 thatme n my wife just purchased we have a jvc radio and we r trying to install it i dnt have a clue
go to a local car audio shop and tell them that you need a wiring adapter and a dash kit for your vehicle and they will get you what you need
metra part numbers for what you need
dash kit 99-5510
wiring harness 70-1770
18helpful
5answers
Radio wiring diagram for 94 dodge dakota
94 dodge dakota electrical diagram,electric brake hookup.there is 6 wires off the brake switch witch one do I hoke the switching wire from the syncronizer to?
in my 94 dodge dakota when i turn my lights on sometimes all extior lights work and dash one dont and when i turn my blinkers on all my gauges bounce with the blinkers its weirdd
1helpful
3answers
Do the jvs have a memory wire. I tryin to put this in a 2001 nissan altima. I need to know if the car have a memory wire for this redio.
You need to hook up the yellow wire from JVC to the yellow/green wire in car(12+ constant memory) and the red wire from JVC to purple from car(switched 12+ volt accessory)
Hope this gets you tuned in!
2answers
94 dakota sport wire/light problems.
check to see if both headlights share a common power or ground.
1helpful
2answers
How to put a cd player in place of factory stereo in 1994 dodge dakota. Need wiring diagram in color.
usually you can buy an adapter that will plug into the factory wiring i picked mine up at wallmart
Car Audio & Video Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
 Francisco Mauricio...
Ekse
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
