Question about GE Washing Machines
SOURCE: Front Loading Washer LOUD NOISE
IF IT ROARS LIKE A JET PLANE TAKING OFF, THE SPIN BEARING IS FAILING. PROBABLY, THE REAR SEAL HAS FAILED ALLOWING WATER TO GET INTO THE BEARING.
THE BEARING HAS LOST ITS LUBRICATION SO IT IS GETTING DRY. IT WILL CONTINUE TO GET LOUDER AND LOUDER THE LONGER REPAIRS ARE PUT OFF.
THE ENTIRE BACK HALF OF THE OUTER TUB WILL HAVE TO BE REPLACED. THE BEARING IS PART OF THAT ASSEMBLY. CAN BE A COSTLY REPAIR.
Posted on Apr 05, 2008
SOURCE: Microwave makes loud noise and does not heat. Smell of light burning
Chances are you have a bad magnetron.
If
it's within the magnetron portion of the warranty (usually 5-9 years)
but out of the original full warranty (usually 1 year), then your
manufacturer will cover the part cost, but not the cost to visit you or
the labor charge to do the work.
If
you or someone you know decide to look into it, we have critical safety
information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your
thoughtful rating of our answer.
Posted on Jul 28, 2008
SOURCE: kenmore front load washer #44072 drum banging noise
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
Posted on Apr 03, 2009
SOURCE: Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Posted on Apr 06, 2009
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
Aug 10, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
May 16, 2010 | LG WM3431 Front Load Washer / Dryer
Oct 20, 2017 | GE WHSE5240D ENERGY STAR Super Plus 3.2...
Apr 20, 2009 | Kenmore HE2 Plus Front Load Washer
Sep 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Aug 06, 2008 | Frigidaire ATF6000ES Front Load Washer
Oct 21, 2007 | GE WDSR2080D Top Load Washer
Oct 12, 2007 | Washing Machines
Dec 07, 2006 | GE WBSE2090A Top Load Washer
Jun 29, 2006 | Kenmore 43042 Front Load Washer
70 people viewed this question
