Question about Optics
My sites for my umarex (Ruger) 0.177 pellet gun does not allign vertically.I am able to adjust it horizontally. Itis shooting 6" consistently. Please advise what I amy be doing wrong.
Posted by Richard on
5 Related Answers
bestdarngood
Benjamin Patri
  • 3037 Answers
SOURCE: horizontal is flickering
flickering as the picture becomes smaller and bigger or are there lines showing up? Please describe it better if you can so I know exactly what you are seeing. Any color changes?
Posted on Jun 28, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Sony kp53v80 Red convergence stuck vertically
Did you replace the convergence ICs? The 4.7 ohm 1/2wwatt resistors and the pico fuses? Let me know and I will assist you, as often sonys will blow the 3.5 pico and a few of the 4.7 ohm 1/2watt resistors when the Ics fail.
Posted on Jul 28, 2008
Benimur
Louie Role
  • 6966 Answers
SOURCE: Horizontal lines moving vertically from bottom to top of monitor screen
Your post/description indicates a likely AC hum riding on the video signal. This cold be caused by:
  • loose cable/connector;
  • faulty capacitor on the unit's power supply regulator circuitry;
  • electrical intereference which could be caused by external drives, subwoofers, electronic ballasts of some lamps, any electrical/electronic devices physically near the monitor.
The 2nd possibility would mean that the unit has toi be opened. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 23, 2008
Anonymous
  • 38 Answers
SOURCE: 60pp9202/17f Cant adjust Red Horizontal convergence
chang the convergence ics
Posted on Oct 13, 2008
Anonymous
  • 261 Answers
SOURCE: headlight adjustment
before you do any thing make sure that the bulbs you installed are perfectly seated in its place inside the assembly if it is not seated properly the lights wont focus properly
Posted on Nov 16, 2008
Can't find the specs in ftbs. my Gamo .177 Bone Collector is rated a 1300ftps. How far can expect to shoot accurately with this break barrel pellet gun?
Depends on who is shooting. But just test your skills on a 75 yard range. Shooting competition, with the special competition guns are shot at 10 meters (about 30 yards) Without a scoop, they easy shoot 80 % of all pellets through one .177 hole on 30 yards.
Mar 12, 2015 | Gamo Bone Collector .177 Caliber Hunting...
How can I get an owners manual?
Do an on-line search, companies will often allow you to download the whole manual to save them the time. Type into the search box the whole name and model and add manual.
Nov 03, 2014 | Umarex Ruger Explorer Youth .177 Cal...
yes,
Most any good gun dealer should have some, I prefer the target model with the heavy barrel. Adjustable sights ar a must for any accurate shooting with a pistol, also use only the standard velocity ammo or the target ammo. you will be far more accurate with these.
Jul 08, 2014 | Computers & Internet
What is the best load for your 168gr classic hunter in 308 win
Assuming that your Ruger has a potential for better accuracy (some guns just wont shoot any better than that) you'll have to work up a special load for the Ruger that will shoot more accurately.. What's good for one gun isn't necessarily good for another.. Also, in my experience, the Ruger M77 hasn't shown me much for good accuracy... I've seen some Brownings, though, that shoot very, very good...
Mar 17, 2014 | Retail Supplies
How to repair a ruger air hawk .177
well for starters, there is no firing pin, second, without major machinery, you can't fix a spring powered air rifle, any of them. It is impossible, major jigs and fixtures hold these things while the spring is removed and replaced. You might try crossman, they do a lot of repairs.
Jul 30, 2012 | Umarex Air Ruger Air Hawk Air Rifle .177...
Why my crosman recruit .177 shoots inconsistently?
I hear that the ammo has alot to do with that. .BB on a unrifled barrel gun are not as good as pellets. Lead pellets ride on the rifling in the barrel. And also your sites could be out of line. One man took the inner barrel out of the outer barrel and bent it over his knee slighty.His rifle was shooting high. On his daisy model # 880 Powerline.. But I would not go that far.A unrifled barrel is best for BB's.only.Hope I can help you out.Yours truly Joseph Alexander Bagli.
Jul 10, 2012 | Crosman Recruit Multi-Pump .177 caliber...
How to sight in crosman extreme g1 pellet rifle scope
You would sight in an air rifle scope in the same manner as any other standard scope that you might find on a rifle:
You want to secure the rifle as best you can with the sights pointed towards a target, which should be set at the desired distance.
Reduce the error of your sight adjustments either by mounting the rifle in a gun mount or simply resting the stock (not the barrel!) on a solid surface such as a table.
Make sure that the weight of the rifle is carefully supported and the **** is firmly pressed into your shoulder. Looking through the sights, aim at the very center of the target (which for your purposes can be as simple as a piece of paper with a dot drawn in the middle).
Take time to ensure a careful shot, and be sure to avoid any shaking, utilizing the support of the mount/table (try resting the fore-grip of the stock on a roll of paper towels if you're having trouble keeping the rifle steady).
Once you are confident with the placement of the cross-hairs over the center of the target, gently squeeze (don't pull) the trigger.
Determine where the pellet struck the target, and adjust the scope accordingly; while every scope is a little different, the same basic principles for adjustment apply. Unscrew the caps on the top and side of the scope, and carefully read the markings on the adjustment dials.
If the pellet struck low, twist the dial on the top of the scope 'up' (the markings should specify clockwise/counter), and if the pellet struck high, twist in the opposite direction. If the pellet struck to the left or right, follow the same procedure for the dial on the side of the scope.
If the pellet struck low and to the side, make the vertical (up/down) adjustments first, repeat the shot, and only move on to make adjustments left/right once the pellet strikes in vertical alignment with the center of the target.
Take your time, and adjust in increments of only 2-3 clicks to start. Repeat the procedure until the pellets are striking consistently in the center of the target (if you're having a hard time remembering which shot went where, replace the target and continue.
Once you are satisfied with placement of your shot groupings on the targets, replace the dial covers on the scope.
Tips and Notes:
- In order to maintain the accuracy of your rifle, try to avoid resting the rifle on its scope and try to prevent the barrel from contact.
- Take note of your rifle's range, and be aware that the further away you place the target, the less consistent your results will be.
- Be realistic; don't attempt to sight in an air rifle at 50 yards. Remember that even with a rifle that has been professionally sighted, good results still come down to the accuracy of the shooter.
-Sight in your rifle at a range where you are confident in your own abilities; start with a closer target and only move back (i.e. sight in at a greater distance) if necessary.
Further Instruction:
http://www.chuckhawks.com/sight-in_rifle.htm
http://www.youtube.com/watch?v=lLirsAFpsfE
May 05, 2011 | Sport & Outdoor - Others
I have an rca model hd52w67 tv and there is a problem with the picture. the picture has a red and green picture that don't allign by about an inch. I think it is in the picture guns but i cant find a...
Do not align the guns! they are located facing up toward the mirror; they are picture tubes! covered with big glass lenses! heavy!
instead look for a red/green/blue adjustment knob on the set's front; the buttons should say: convergence or, crosshatch push the crosshatch button: once you have three vertical lines crossing three horizontal lines; just merge them using the other R/G/B knobs untill you have one white vertical line and, one horizontal line crossing in the center of the screen.
(you may have to find the controls on the remote using "setup")
Feb 11, 2010 | RCA Televison & Video
Optics Logo
169 people viewed this question
Top Optics Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you an Optic Expert? Answer questions, earn points and help others
