General Electric A735 Digital Camera Logo
Question about General Electric A735 Digital Camera
I have a GE a735. It wont stay on
I have a GE a735. I do not have my charger that plugs into an outlet, but I do have the usb cord. Can I charge my camera with the usb cord, because I have changed out the batteries a few times and it just wont even turn on for me.
Posted by caleb_steven on
Anonymous
  • 33 Answers
Go to the GE website, consult your manual if you still have it, go to RadioShack and see if they might have a replacement charging cord. Maybe at the GE website you can order the charging cord. Good luck.
Posted on Aug 04, 2009
2helpful
2answers
My panasonic Hc-v100 camcorder is not charging when plugged in to USB cable - cursor light is not flashing and battery is running down
you DON'T charge the camcorder with the usb cord,you only move files between cam and computer,you need a power cord that plugs into the wall,see pic, LETO 2A AC Power Charger Adapter USB Cord For Panasonic HC V100 HC V500 HC...
ihave the same camcorder,
Can I charge my Craig Power Bank model CMA3121a from a wall outlet, rather than the computer?
You need a mains USB charger, it is a standard 5volts device with a minimum of 500ma. They are easily available. Plug the USB cord into the charger instead of the PC.
My phone will no charge while it is on the charger
Sometimes the block transformers on phone chargers go bad. I'm assuming it uses a micro usb plug like most phones do now. The easiest way to check is to borrow a charger from someone else or if you have a kindle charger use it to see if the phone will charge. If it does don't go back to the phone store to get another one because they charge an arm and a leg. You can order the chargers for most phones online for half of what you pay at a phone store.
Feb 02, 2014 • Cell Phones
1992 buick century lighter wont work
If the lighter outlet works with a cig lighter, the plug for your GPS may not be making contact with the center point in the outlet.
may have dirt and debris in the bottom of the outlet
You may also have a blown fuse.
How do i charge my camera so that i can explore
You can charge the battery in two ways.
Use the supplied battery charger. Remove the battery from the camera, put it into the charger, and plug the charger into a power outlet.
Connect the camera via a USB cord to a powered USB outlet. Be aware that not all computer USB ports put out enough current to charge the battery. You might want to consider a cell phone charger that plugs into a power outlet.
1helpful
Bought I touch from a friend....now battery won't take a charge.
Ok problem number 1) if your using a wall charger, then you outlet has
been blown and need to switch the cord to a completely different outlet.
If your using a USB plug-in charge cord, then either 1) he sold it to you
with a bad battery. 2) you have a cord with a short in it or the head of it
is slightly dislocated itself. 3) your computers USB port is not working
properly, which means you need to go into your computer settings and
manually update your USB ports.
1helpful
2answers
Charging the mp3mp4 player
  1. Get a USB wall charger. These are AC adapters that plug directly into the outlet. You then plug the USB from your MP3 into the port on the adapter.
  2. Charge your MP3 player on the go. There are also charging kits that plug into the cigarette lighter or power plug in your car. These kits come with a DC power adapter that has a port on the end for you to plug in your MP3.
  3. Acquire Apple iPod specific chargers. When you need to charge your iPod music player through an outlet, look for the Universal USB car charger or the Universal USB travel charger made specifically for Apple products.
Make sure that you have your player on a power strip or surge protector so that if you get a surge you wont fry your player.
1helpful
2answers
Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
2answers
Top General Cameras Experts
ZJ Limited
ZJ Limited
Tony Parsons
Tony Parsons
Are you a General Camera Expert? Answer questions, earn points and help others
