SOURCE: andis pet clipper kit
You are most likely referring to the snap on comb.. most of them are designed to use only with a 30 or 40 blade. This is the only way you will get a proper cut with them. Good Luck with your old "guy". And I'm sorry hes petrified to go to a professional groomer.. seems you have been taking him to the wrong ones. :)
SOURCE: Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
SOURCE: I purchased a Geo Hunter clipper blade sharpener.
hi, not sure of the sharpener you have but to be honest it is very hard to sharpen blades getting the correct hollow grind is essential we receive lots of blades that have been ruined by other sharpening companies.
SOURCE: when i cut hair my andis master clipper seems to
mcdevito75 here, Sounds like the blades need to be sharpened, refer to the shavers brand name plus .com for blade replacement or replace the shaver.
SOURCE: clippers dont work at all,
A reason your trimmer may not work is that the hair is trapped inside the trimmer and not allowing it to function properly.
Here is a link to a video to cleaning hair clippers.
www.youtube.com/watch?v=43CpUK2AghA
If the problem persists, then you most likely burnt up the engine in the clippers and there is no easy solution other than buying a new trimmer.
