The master volume control no longer controls the volume. The signal is strong enough to be played by the amp, but the master volume knob can no longer adjust the volume. What could be the problem?
i have a used oem replacment mast. vol. might just change it,how many ac volts should i be getting from the transformer wires? thanks 4 da input.its def. dirty,who has the diagram for free?i have a used oem replacment mast. vol. might just change it,how many ac volts should i be getting from the transformer wires? thanks 4 da input.its def. dirty,who has the diagram for free?
You can't post conmments that contain an email address.
1. Sounds like it's the input jack., but it could be the volume knob. Have you tried turning Gain1 and Gain 2 or the Clean Channel volume? Try them first when you're plugged in to the jack on the left , then when you're plugged in the back. If none of these work, it's most likely the preamp.
2. Even if the preamp is shot, there's a quick fix - get a guitar preamp or an effects pedal - they have volume and tone controls.
3. Finally - many pros just plug into the aux jack(on the rear panel) and control the volume and tone through their instruments.
Hope one of these works. Good Luck.
Hi, I can help you with your question. On the face of the effects, towards the right side, there are three settings that can be adjusted: DRIVE, TONE and VOLUME. The VOLUME knob is your master volume. The expression pedal can adjust volume, but it's output volume is controlled by the master VOLUME knob we just identified. I hope this has helped you, and if it has, could you please click on the "helpful" button ? Thank you!
Hi, use the RCA/Phono connections for the Tape In & Out. The level will be set by the Master/Main fader. If that is not so convenient (& assuming it's a PMP4000?) there should be a "Main 2" output & connections with the level controlled separately to Main 1 via a Knob / Rotary control over to the right above the "Mono" fader... Hope that helps... Good Luck!
You left off the one bit of info we need... however, make sure the volume control on the keyboard is around the halfway point... If it is way down, turn it up and reduce the channel volume knob some. Make sure the cable from the keyboard is an instrument rated interconnect and not one intended for speaker (usually marked as such). Make sure the keyboard AND this amp are powered from the SAME receptacle... even if you have to run an extension cord. Listen with headphones on your keyboard to make sure the sound is clean there.
It is not clear if the volume knob you are talking about is in the amp or the guitar... SINCE you said you verified the amp is OK I have to assume the volume control you are talking about is in the guitar and my answer is based on that...
I SUSPECT that the resistance element and/or the wiper in the volume pot is damaged. One other possibility is the soldering of a wire to the volume pot may be bad. If you are competent with a soldering iron you could replace the pot yourself or take it to a competent guitar shop for repair. I would myself suggest you open the electronics and look for anything obviously wrong. I have ALSO seen one other problem where one lead of a pot is touching the CONDUCTIVE paint in the cavity where the controls are. If the shaft nut becomes loose and the pot slightly rotates this can happen, grounding out the signal.
It sounds like your volume control is dirty. You will have to disassemble the amp enough to get access to the volume potentiometer which is soldered to the circuit board. There will be a square hole in it that you can spray some contact cleaner into the control. Use only contact cleaner as anything else could damage the control. Use a small squirt and rotate the shaft. If this doesn't solve the problem you may have to replace the control. While you have it apart, examine the solder side to make sure all the solder joints are perfect especially those on the controls. A bad solder joint can also cause the same problem. Before you take the amp apart unplug the power with the amp on and the volumes turned down. This will discharge the capacitors so it will be safe to work on. I hope this helps.
Your amp has two channels - "normal" and "drive." When you are on the normal channel, the "volume" knob controls your gain. In the "drive" channel, the drive knob controls your gain. In both channels, the "master" knob limits how loud the amp will get.
Most likely, you are on the drive channel, so the volume knob will have no effect. Try pushing the "channel select" switch. You should notice the channel indicator lamp (next to the drive knob) turn off. When it is off, you are in the normal mode. Yellow = drive, and red = "more drive."
Experiment with different settings to get a variety of tones.
To get the most out of this amp, try reading the manual, available online here: http://www.fender.com/support/manuals/pdfs/manuals_elec/guitarpdf/Hot_Rod_Deluxe.pdf
First make sure you have the TRIM knob positioned correctly. When playing loud the Red Led should just blink a bit so you know you're not overloading the preamp and Digital sections. The Twin Reverb Patch is a clean place to start so select that first. On this amp it's a good idea to set the MASTER to 5 and use the VOLUME control at as low a setting as you can. The GAIN control should be set under 4. You better sound crystal clear on this setting. Try turning up the volume to see how loud you can get without breaking up. It's a guitar amp so there will be some grainy distortion but it should be very light. I bet you get through this test without much trouble. After that you need to be very careful about what settings you're using since many of the presets may not mesh with your guitar pickups. You should concentrate on tweaking one highgain setting and learn about how the controls interact. The amp is so much more complicated than a 10 knob standard guitar amp. Most people need to put in some time to get a handle on it.
As far as the tubes go, typically they can get microphonic which was a problem with versions 1.1 and 1.0 of this amp so check that. Fender had a Cyber twin upgrade kit way back to fix this but if you have version 1.2 or 1.3 that's not it. Problems with this amp are typically caused by control setting more often than an electronic problem but this reponse should get you started figuring it out.
MYREL
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
