When you start the cycle and does it beep once and then show "CE" .. There is a communication error between the machine control and motor control.
There may be some Conformal coating on serial communications pins between the machine controller and motor controller.
After disconnecting power to the unit, try scraping this coating off the pins.
Check the resistance values between the serial communications pins with the connectors in place.
Make sure the harness does not have a bad connection.
Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
maybe the Drive motor thermal protector has opened.
Motor controller is not powered or fuse has opened.
Check the fuse on the motor control board and see if it is blown. If so, You could just have a bad board, but it may be a drive motor or pump motor. The most common thing is for the pump seal to leak into the pump motor and cause a short.
The CE code means the 2 boards can not communicate with each other so be sure to check the wiring connectors between them. Post back with what you find out.
