Radio Communications Logo
Question about Radio Communications
Supertooth One Pairing Instructions
Posted by Atkinson on
2 Related Answers
Anonymous
  • 49 Answers
SOURCE: pairing supertooth
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.php
Posted on Apr 09, 2010
Anonymous
  • 943 Answers
SOURCE: Unable to Pair Samsung Galaxy Pro with Supertooth
it arises commonly because most of bluetooths cannot support more than one device(if once connected they dont connect to other device) ....
Posted on Oct 31, 2011
5helpful
3answers
1helpful
I am having trouble pairing my Supertooth Voice R161 with my Blackberry 9780. ( It worked fine with my old Blackberry 8750). I follow the instructions and use the pincode 0000 but get the message back that...
my Supertooth Voice R161 is not pairing with my iphone?i try 0000 1234 4321 8888 1122 2211 but not any happning?any one help me please thanks.
Sep 16, 2011 • Cell Phones
34helpful
2answers
Having trouble pairing phone with Blue Ant ST3
  1. If the Supertooth 3 is on, turn it off by holding down the green Multi-Function button for about 5 seconds (until you hear a voice announce "BlueAnt ST3 powering down").
  2. Hold down "Vol " and the green Multi-Function button until you hear a loud siren/distinctive tone.
  3. The Supertooth 3 will turn on. Hold down the green Multi-Function button for about 5 seconds to turn it off again.
  4. The Supertooth 3 has now been reset: all pairing and other information has been deleted. When you turn the Supertooth 3 back on again it will prompt you to select a language and then go into pairing mode.
You will now need to re-pair your phone with your Supertooth 3.
9helpful
2answers
I have a BlueAnt Supertooth BTSLBC3 car speaker that won't pair up to my new BlackBerry curve 8530 phone. The BlackBerry won't see the BlueAnt Supertooth BTSLBC3. The BlueAnt Supertooth BTSLBC3 is paired...
Pairing Your BlueAntStep 2: Activate Pairing Mode on the Supertooth Light
  1. If the microphone arm is open, close it to turn the Supertooth Light off.
  2. Press and hold the answer button.
  3. With the answer button held down, open the microphone arm.
  4. The lights will start flashing red and blue, indicating that the Supertooth Light is in pairing mode.
You now need to activate Bluetooth
1helpful
I need the code to pair to my phone I have the device found and I have to enter the pairing code, which I do not know
Blueant Supertooth Light Pairing code is 0000 (four zeros)
Click here to view your user guide and instructions in PDF format:
http://www.supertooth.net/PDF/ST_Light_English.pdf
You'll need Adobe reader to view it. It's free. Download here if you need it:
http://get.adobe.com/reader/
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
1helpful
BlueAnt Supertooth Light wll not connect to apple iphone When I switched to a iphone 3gs it will recognize the devise but when I place the code in which is ''0000'' it says the pin in invalid.
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etc
18helpful
2answers
Blueant supertooth not pairing to samsung omnia i900
Hallo Stu,
Try following the below instructions, if you haven't already tried them..
First Time Pairing to your Bluetooth Mobile Phone
When you turn ON your Supertooth Light for the first time, it will automatically go into Pairing mode ready to be found by devices in Bluetooth searches. This will be the case until you have successfully paired a phone. If you have already paired a
phone, please go to the next section.
1. Power ON your Supertooth Light. The Bluetooth Indicator (3) will turn a blinking
red/blue, The kit is now in pairing mode.
2. Go to Point 3 in the next section, “Pairing to your Bluetooth Mobile phone”
Pair the SUPERTOOTH LIGHT to your Bluetooth mobile phone to create a “Pairing”
link, or audio connection between the two. This has to be only done once when first connecting each new phone.
1. From OFF, Press and Hold the Accept Button (1).
2. While holding the Accept Button (1), switch the kit on (Press-and-release the
Microphone Shaft (5)).
3. The Bluetooth Indicator (3) will turn a blinking red/blue, when you see
this, release the Accept Button (1). The kit is now in pairing mode.
4. While the kit is in pairing mode, access the Bluetooth menu of your phone. Turn on the Bluetooth function then execute a Bluetooth search, or discover. (See your phone’s manual for specific instructions.)
5. When the phone displays the list of Bluetooth devices, select ST LIGHT.
6. When the phone asks for the password, enter 0000 and press Ok.
7. Set the ST LIGHT as a trusted/authorized device, if this is option in your phone.
Important Note: The kit is now paired. Most phones automatically connect to the
kit after pairing. With some phones you need to connect manually after pairing.
Go back to Bluetooth > Paired devices > highlight ST LIGHT > press
Options > then press Connect.
When connected you may see the Bluetooth Symbol on your phone change
slightly, either inverting in color or changing to a headset or car symbol. The kit
is now ready to use.
Repeat steps 1 -7 above for each new phone you want to use with the
Supertooth Light.
This was copied from the user manual, which you may or may not have already.. Here's a link to a .pdf file of the manual which you can also save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
4helpful
How can i reactivate my blueant blue tooth on my motorola ic902?
Supertooth Light.
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
8helpful
Just bought a iPhone 3G and i have a BlueAnt Supertooth light and the iPhone isn't discovering it...help?
Supertooth Light.
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Cell samsung SGH-F250 with bluetooth motorola h500
ACTIVATING THE BLUETOOTH
You must activate the Bluetooth feature of your phone to be able to establish a Bluetooth connection
between your phone and your SuperTooth kit as well as with other Bluetooth devices.
1.
Press Menu > Settings > Bluetooth > Activation > On.
2.
Press Back as many times as needed to return to standby mode.
PAIRING TO THE CELLULAR PHONE (Not possible while charging the SuperTooth)
Pairing will create a link or connection between the two Bluetooth devices - the SuperTooth kit and your phone.
1. Bring the cellular phone at about 20 cm from the SuperTooth.
2. Turn off the SuperTooth and wait for about 4 seconds.
3. While pressing the Answer Button, turn ON the SuperTooth by sliding the Power Switch to the right. Keep the Answer Button pressed for approximately 10 seconds until you hear a distinctive tone and the Bluetooth indicator LED changes from blinking blue to alternately blinking of red and blue. The SuperTooth is now in pairing mode.
4. While the SuperTooth is at pairing mode, access the Bluetooth menu of your phone. Press Menu > Settings > Bluetooth > My devices > Search new device. The phone will then search for pairable devices until it displays them in the list.
5. Highlight SuperTooth then press Select.
6. Enter PIN “0000” then press Ok. (Wait until “Paired with …“ and “Connected” will be shown briefly.)
7. Press Back as many times as needed to return to standby mode. Pairing is successful if the alternating red/blue lights of Bluetooth Indicator stops and then change to plain blinking blue. Normally, the phone would also show briefly on its display if it’s already paired and connected to SuperTooth or if pairing with it failed.
The SuperTooth kit is now ready to use.
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
