Question about Electro-Harmonix The Wiggler
Guitar pedal wiring
I replaced the jacks on my Graphic Fuzz guitar pedal. After rewiring it doesn't seem to work. Does anyone know the wiring layout for this product? Thanks.
Posted by bstrike828 on
  • bstrike828 Aug 04, 2009
    I played around with it for a while last night and got it to work. Thanks for your help though.
PolyrhythmFX
    Scholar:
  • 109 Answers
If you only replaced the jacks, then check where you soldered your wires. The ground wire from the circuit board an/or switch will be wired to the sleeve of the jack. The tip of the jack would be wired to the output lug of the switch. Also check the wiring on your in jack to make sure the correct wire is going directly to the switch from the jack's tip. The ground wire will go from the sleeve to the circuit board and/or ground lug on the switch.
Post your email and I can help you out if you do not fix it.
Posted on Aug 11, 2009
Imput plug not picking up guitar and making fuzz noise
Inspect the jack for damage... including solder where it attaches to the circuit board. Common problem when someone trips over a guitar cable. Loop the cable through the handle of the amp to REDUCE the chance of this failure.
Sep 02, 2011 | Fender Fm25dsp 1x10' Guitar Combo...
My Voodoo Lab Super Fuzz stop working. The led doesnt light, and the effect sound doesnt work, but the bypass signal is unaffected... I opened it, and test the resistences they seem to be OK... I don't...
If you are using battery, replace it. If you are not using battery, check your pqwer adapter. Internally, the pwer connectors and soldering around it are chronic problem,
Feb 19, 2011 | Voodoo Lab Super Fuzz Guitar Pedal...
I have a Fender Deluxe Active Jazz Bass thats makes this really really loud buzzing earthy sound. It seems to happen spontaneously, in fits and starts, but particularly if the cable input on the bass is...
This sounds like either a bad guitar cable or a bad jack in the guitar. Possibly your friend is not as qualified to find these intermittent problems as needed? These jacks are really junky and often have riveting of the barrel come undone... especially if the retaining nut is overtightened. The LONG barrel like jacks are notorious for failing. You have all the information you need to solve this problem. First try a different guitar cable... (often they are broken or intermittent at the end where they flex). If that doesn't fix it, replace the jack in the guitar. Also verify that the conductive coating paint within the guitar is grounded. Sometimes the contact to it is destroyed when the volume control shafts or jacks become loose and they depend upon the shaft barrel to ground the paint.
Jan 30, 2011 | Fender Deluxe Active Jazz Bass Electric...
I have a Zoom 9000 Guitar effects processor, and although I have its original adapter, and although its red light flashes and power is on after plugging in everything, I could not get any sound from my...
I'm a Zoom 9000 owner (since '93, I think) Did you try batteries only? Are you plugging the guitar into the "in / power" jack and not mistakenly using another jack? When you plug in the guitar, in to the Zoom 9000 does the window come on with the settings shown? Sorry, I know some of these are obvious but always the chance of us being human. If all that seems fine, then I would read though a manual to see if maybe it is a setting problem, i.e., sound somehow got inadvertently turned off. If you don't have one, an internet search will lead you to one. Sorry, wish I knew more.
Oct 14, 2010 | Zoom A2 Acoustic Effects Pedal
Guitar fuzz pedal foot-switch problem
Replace the switch. These "toggling" switches can and do go bad and fail to toggle.
Dec 07, 2009 | Music
Marshall mg100hdfx loud fuzz and distortion and no guitar sound
Check your input (guitar signal).
Also, check your gain and volume levels.
Make sure that you have a reliable, steady, and clean power source as well.
If the problem persists, contact the store from which it was purchased. There are a lot of things that can go wrong internally with the cheaper Marshall models.
Jun 25, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Static Noise from guitar amp.
I take it you have made sure that both the cable to the distortion box from the guitar and the cable to the amp are both good. From the description you give, it sounds like there is no signal getting to the pedal. If the cable is good, then the next likely suspect would be the input jack on the fuzz box. Try wiggling it a little with the guitar cable in place to see if it is loose. Some input jacks are unbelievably cheap and flimsy. A crackling sound (static like) is almost always a bad connection. If it was the output jack, I would think that the guitar signal would come through a least a little bit, but you might want to try wiggling that one, too, if the input jack isn't the culprit.
Another possibility to check is the battery, but this doesn't seem as likely. Some effects units devour batteries, especially units that use 9V batteries. I have a multi effect pedal that kills a 9V in about an hour.
Jan 22, 2009 | Epiphone Les Paul Studio Electric Guitar
Electro-Harmonix The Wiggler Logo
439 people viewed this question
Top Electro-Harmonix Music Experts
Marvin
Marvin
Are you an Electro-Harmonix Music Expert? Answer questions, earn points and help others
