Dryers Logo
A
Anonymous Posted on Oct 27, 2018
My whirlpool Ultimate care '' dryer is overheating and drum does not stop rotating when the door is openstop
Chris Huff
Level 3:
Top Expert:
  • Whirlpool Master 6,289 Answers
  • Posted on Oct 27, 2018
Chris Huff
Whirlpool Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2020237
Points
74913
Overheating problem can be caused by stopped up ventilation, grounded out element, or bad thermostat. Rotation problem would be a defective door switch.
5helpful
Drum doesn't turn
Check this out
Bonus
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
We have a Whirlpool Ultimate Care II gas Dryer that is getting intermittant heat. Sometimes it will heat, sometimes it won't. Iin addition, today it stopped rotating as well. Ideas?
Could just be a matter of wires coming loose. The movement and vibration of the spinning could have shaken wires loose. look for any wires not connected to anything.
Dryer drum won't rotate
if there is no air coming out of your vent on back of dryer then it would be likely your motor has gone out.
Jun 24, 2009 • Dryers
Whirlpool Dryer Drum Won't Rotate
sounds like your drum belt has broke. remove two phillips screws at lint screen. pull top towards you then up. you will expose drum.
Drum will not rotate in LEW0050p Dryer
hello is the door making the switch if thats ok check wires see if any are loose if thats ok .at the bottom of the machine next to the motor theres a part callled a capacitor its got 2 wires coming off it this can stop the dryer rotating i hope this help
Whirlpool Ultimate Care II - Gas Dryer - Drum Won't Spin
If you are handy with tools, try to remove the back panel and feel the belt that should surround the drum. If access is that limited, try to turn the dryer on its side and you can get to the motor from the bottom. But like the guy said before, call a pro if you can't do any of this.
5helpful
Whirlpool Ultimate care ii Dryer wont tumble
If your dryer doesn't tumble, check these:
Belt,
Motor,
Door switch.
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
Remove the belt,
Check for obstructions in the blower fan housing,
Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
Go here to see a diagram for your model:
one of two types. "H" or "J"
http://www.repairclinic.com/0079.asp#DiagramH
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
