All parts are brand new but the flame for the oven burns too high. How can the oven flame be adjusted for the new parts?
Generally adjustment would not be required. When first lit the flame would be at maximum power but reduce as the oven heats up and the thermostat takes control.
Your description indicates the thermostat is not taking control - perhaps it wasn't installed correctly or it simply isn't working.
Testimonial: "The orpheus was turned upside down so the oven was burning for natural gas instead of LP gas flame. thank you for your help."
SOURCE: Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
SOURCE: Tappan Series 110 Gas Stove Owners Manual
stovetop works well, oven will not ignite. Whats up?
SOURCE: oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
SOURCE: Garland stove oven pilot light does not stay lit
If there is any adjustment, it would be a small screw on the oven control accessible with the oven control knob removed. This adjustment affects the size of the top burner pilots, but I'm not sure about the oven. The oven pilot orifice may have an obstruction, or if the flame is actually normal size where it covers the thermocouple when it burns, you may have a thermocouple problem.
SOURCE: Kenmore gas stove. Oven burns big flame which soots
The manifold needs to be cleaned and adjusted could have rust etc in it Not a good thing to do yourself unless you know what you are doing
