SOURCE: Both radiator cooling fans won't turn on vehicle overheats
The fans come on only when hot or the AC is on. There are many fuses that have to be good for it to work. The fan relay should have 2 pins hot with the key on, The other 2 should be ground. with the key off one should be hot and the other can then be ground the other pins that are ground one of them is the fan. the other becomes ground when the computer turns the fans on. If you don't have a pin thats hot at the relay all the time then theres a blown fuse or even the power wire from the battery at the battery
SOURCE: temperature guage not working and engine overheated when stopped in trafic
The powertrain computer turns the fans on through the cooling fan relays, based on information from the coolant temperature sensor. The fans will only come on when the coolant temp. is pretty high-varies by manufacturer, but it is over 200 degrees, some as much as 230 degrees. So the fans will not come on when engine is started, but they should come on before the engine overheats. You should have them checked. Also find out if the temp. gauge sending unit is separate and different from the coolant temperature sensor-on most cars, they are separate, maybe not on yours?
Free advice from a shadetree-not worth a lot, eh? lol.
SOURCE: Radiator fans will not turn on.
replace fan switch. depending what make vehicle, it could be located
on the side of radiator, on thermostat housing, on cylinder head.
A/C refrigerant pressure exceeds 1 310 kPa (190 psi).
After the vehicle is shut off if the engine coolant temperature at key-off is greater than 140?°C (284?°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The BCM and PCM/ECM command High Speed Fans on under the following conditions:
Engine coolant temperature reaches 110?°C (230?°F).
A/C refrigerant pressure exceeds 1 655 kPa (240 psi).
When certain DTCs set.
The three relays are located in the under hood fuse / relay box ! You need to have it checked for DTC'S -diagnostic trouble codes ! An you need a GM Tech 2 scan tool !
This diagnostic procedure supports the following DTCs:
DTC P0480 Cooling Fan 1 Relay Control Circuit
DTC P0481 Cooling Fan 2 and 3 or S/P Relay Control Circuit
DTC P0691 Cooling Fan 1 Relay Control Circuit Low Voltage
DTC P0692 Cooling Fan 1 Relay Control Circuit High Voltage
DTC P0693 Cooling Fan 2 and 3 or S/P Relay Control Circuit Low Voltage
DTC P0694 Cooling Fan 2 and 3 or S/P Relay Control Circuit High Voltage
