Question about Refrigerators
MODEL:SJ-F76PS POWER SUPPLY ON MOTOR FAN NOT WORKING FAN GOOD???THANKS
Posted by Harley Choureemootoo on
Chris Huff
    Top Expert:
  • Refrigerators Master
  • 6,289 Answers
If getting correct voltage,replace fan motor.
Posted on Oct 27, 2018
Testimonial: "MODEL SHARP SJ-F76PS NO POWER IS COMING TO MY PLUG TO WORK MY FAN MOTOR INSIDE MY REFRIGERATOR WHATS WRONG NO POWER GHANGE NEW FAN STILL THE SAME"
  • Chris Huff
    Chris Huff Oct 27, 2018
    Probably a control board problem with
2 Related Answers
Anonymous
  • 44 Answers
SOURCE: 2 year old E machine
Dear zmatt,
Looks like the power outlet or UPS may be at fault. Try a different outlet. That's all I can thik of.
Posted on Aug 01, 2008
Ezrahite
Rofel Lantican
  • 2632 Answers
SOURCE: power supply is good, fans running - no display on
make sure to check the video cable (DVI,VGA,HDMI) if properly connected
if youre using an independent video card and your motherboard has a builtin try to use the integrated to check if the video card is faulty
if you dont have a video card and using the integrated the motherboard might be faulty
Posted on Jul 20, 2010
AVE ERROR CODE 5351 WHAT IS IT?
C5351 Power Supply Cooling Fan Motor Failure The Power Supply Cooling Fan Motor Lock signal remains set to H for a set period of time while the Power Supply Cooling Fan Motor is turning. • The Power Supply Cooling Fan Motor Lock signal remains set to L for a set period of time while the Power Supply Cooling Fan Motor remains stopped.
Aug 26, 2015 | Computers & Internet
Heater fan not working
Check the fuse on the dash board and if this is good then the power supply +B- 12 volt must be checked on the motor. If not the switch can be faulty and it can an open connection or a faulty motor.If there is supply to the motor and it is getting warm then the motor can be stuck and needs an overhauling.
Dec 17, 2011 | Cars & Trucks
Good Afternoon to You, I am currently working on
This means error code of E-1 and E-2. Indoor room sensor defective. Replace it. And also rotate motor manually. If hard, replace fan motor bearings. Helpful?
Jan 04, 2011 | Fujitsu 36CS Air Conditioner
Blower motor doesn't work and has no power to it
Check the blower multispeed control resistor pack is not faulty.
The resistor pack is usually located in the air ducting, in the blower fan airflow.
Basically, +12v power is supplied (via fuse) to the fan speed control switch, which then passes via the selected speed control resistor, to the fan motor. Often a interface relay is used to switch the blower motor high current.
Aug 31, 2009 | Dodge Pickup Cars & Trucks
Charmglow electric fireplace . no light for flame effect
the fan is working. I do not have the flame effect fixed. I find this web site difficult to get any help from.... seems to go around in a circle. Just tell me if it can be fixed.. I want to know about the bulb (?) or whatever makes the flame effect. Nothing seems to be able to take apart , if not do you have a website I can get to for a new one.....thanks....
Mar 25, 2009 | Fire Sense Georgetown Electric Fireplace
FAN NOT WORKING
hi mary,
pull out the fan and check if it is an AC fan or a DC fan. they now uses DC fan in some models.
if it is an AC fan, check its voltage rating and test it directly to the voltage stated in the motor.
if it is a DC, find a power supply and test it with the correct voltage and polarity.
tnx,
drcool
Sep 28, 2008 | Refrigerators
Whirlpool dehumidifier model AD25G0
Your problem appears to be in the power supply from the control circuit to the fan motor. Your owners manual has an 800 number to the Whirlpool hot line for customer assistance.
May 10, 2008 | Dehumidifiers
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
