Question about Danby Dehumidifiers
My danby dehumidifier shcc6026 is making a noise. Sounds like it might be the fan. How do I access the fan?
Posted by Bonnie on
5 Related Answers
Anonymous
SOURCE: Danby Simplicity PHD SHCC6026
without floor drain how to use direct drain
Posted on Aug 03, 2009
Anonymous
  • 117 Answers
SOURCE: Danby Dehumidifier DDR557HE has never dehumidified
either lacks coolant or compressor bad
Posted on Jan 05, 2010
Testimonial: "Thank you, I didn't even know a dehumidifier had coolant. "
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: My Danby dehumidifier will not dehumidify but the
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 10, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: my danby shcc6026 wont dehumidify
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Posted on Mar 07, 2011
Rich Landrum
  • 4736 Answers
SOURCE: We have a DAnby dehumidifier
The E7 Error Code, indicates that the front cover of the unit it no properly in place and making contact with it's removal sensors. Remove and reinstall front cover properly. Be sure to turn the Master ON/OFF Switch to OFF and unplug unit before attempting this.
Hope this helped you solve the problem.
Posted on Jun 22, 2011
We have a DAnby dehumidifier - model SHCC6026. It keeps showing an E7 error. Is there a simple solution to the problem?
Jun 22, 2011 | Danby DHCC6020 Dehumidifier
My danby shcc6026 wont dehumidify
heatman101
Oct 04, 2010 | Danby DDR600R Silhouette Dehumidifier
Loud noise
try to put some lubricant to smooth the work of the fan
Nov 16, 2009 | Danby DDR586R Dehumidifier
Why is there a burning smell coming from my shcc6026 when in dehumydifying mode
It sounds like there may be wires touching each other inside the machine. You may not want to run it until you take it apart and check for burnt wires and definitely don't run it unattended.
Aug 16, 2009 | Danby 60-Pint Dehumidifier
Need operating manual for Simplicity phd, model# SHCC6026. thnks.
where do i hook up a hose to drain water to sump pit on my simplicity dehumidifier?
Jun 10, 2009 | Danby DDR601 Dehumidifier
Jun 29, 2008 | Danby DDR600R Silhouette Dehumidifier
Problems with Danby SHCC6026 Simplicity
It's normal, the motor is running while it's not powered on to make the water filtered in the tank.
Do you get problem with water get on the floor?
Apr 07, 2007 | Danby 60-Pint Dehumidifier
Dehumidifiers Logo
307 people viewed this question
Top Danby Dehumidifiers Experts
Vincent G
Vincent G
Sheldon Dedek
ADMIN Canada
ADMIN Canada
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
