Question about Kwikset Locks & Locksmithing
Kwikset outdoor lock does not worksheets rod does not retreat
Posted by Ronald Moglia on
How do i install a kwikset chelsea lockset
All Kwikset locks come with complete instructions.
For additional information:
Kwikset Customer Support Product FAQs
Jul 07, 2014 | Kwikset Locks & Locksmithing
Kwikset smartcode parts
It might not be the motor. It could be the electronic circuit that powers the motor. I ran into the same problem with a Kwikset electronic deadbolt. I separated the motor from the electronic circuit board and found that the motor was OK. When I couldn't get replacement parts I bought a Master Lock unit. It's not motorized and uses 4 AAA batteries, which last a long time. Kwikset just wants to sell locks, but the same problem exists with Schlage and other brands - including Master Lock. One year warranty on electronics.
Mar 22, 2014 | Kwikset Smart Code
Kwikset keypad deadbolt will not lock or unlock. Batteries OK.
I have included a link to the installation instructions for the Kwikset 909 lock. I think that if you go through the installation instruction routine carefully, you will solve your problem. Pay particular attention to Step 8, the synchronization routine.
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
Apr 10, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Kwikset 730LL-RH handle fall out, How to fix it?
I'm including a link to the installation/assembly instructions for the Lido LL730 3:
http://s7d5.scene7.com/is/content/BDHHI/44594-01
I'd recommend that you contact Kwikset Customer Support if you are unable to repair it:
Kwikset Corporation
Consumer Service
19701 DaVinci
Lake Forest, CA 92610
Kwikset Customer Service
Call: 1-800-327-LOCK (5625)
Here's the link for their customer service page:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Feb 11, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
I replaced the batteries. After inserting them back into the system, the lock does not operate. I have tried pushing program button 3 times and waiting 10 seconds, nothing. I removed the batteries again...
Here is a link to the complete set of installation instructions for the Kwikset 909-15:
If, after following the instructions for replacing the batteries and reprogramming the lock it still doesn't work for you, I suggest contacting Kwikset Customer Support:
Kwikset Corporation
Consumer Service
19701 DaVinci
This is a link to the customer support page:
Feb 02, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
We have a kwikset keyless entry lock and need to reset it.
Try searching the type of kwikset lock from this page:
http://www.kwikset.com/Customer-Support/Product-FAQs/Search-Faq.aspx?prod=FAQ+Categories_Keyless+Entry
Jan 22, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
My numbers on the keypad are worn off of my Kwikset Powerbolt lock where can I buy replacement numbers
Contact Kwikset Customer support:
http://www.kwikset.com/Customer-Support/Overview.aspx
good luck!
Jan 12, 2011 | Kwikset UltraMax Powerbolt 1000
We have a kwikset smart key and the deadbolt part worked fine for months and then suddenly it won't work. Not happy. What to do? Shirley Johnson
You will have to buy a new lock once the "smartkey" locks up its toast. Very bad design unlike the traditional kwikset pin tumbler lock which can be repaired if something like this were to happen but hardly ever does.
Oct 22, 2010 | Kwikset Locks & Locksmithing
I can't find the instructions to install lock.
Here is the installation page for Kwikset. There are some general hints and tips and you should be able to follow the links to a specific lock if you need it.
http://www.kwikset.com/support/installation/default.aspx
Oct 21, 2009 | Kwikset Professional Door Lock...
Locks & Locksmithing Logo
322 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Marvin
Marvin
john h
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
