SOURCE: 1993 goodman status light 4 times blinking
I have a goodman GMP075-3 that won't turn on. I think it is the pressure switch since I do not have a vent blockage. What is a venter and where can I find it??
SOURCE: goodman furnace 4 blinks
Ohm out the safety switches also known as the high limits usually at least two on units they look like little buttons, with two wires going to each one. An open high limit will mean the circuit is not closed and allowing for the system to complete the circuitry to fire the heat, best way to diagnose is to jump out the suspected high limit s/w if the unit runs then you have your answer, but never, never leave the high limit switch jumped w/o the switch.
SOURCE: I have a Goodman GMPN080-4 furnace. The light on
Hi 3 blinks should mean it is the pressure switch there should be a code in the manual or inside of the door
SOURCE: Goodman Furnace GKS9 pressure switch problem
Disconnect the small hose that goes from the pressure switch to the inducer motor housing, at the housing, and stick a paper clip in the tiny hole, and pull it up and down, and twist it. this small hole is probably dirty. good luck.
