Question about Freezers
You will have to get a service tech that can diagnose why it’s not cooling properly
Posted on Oct 28, 2018
SOURCE: chest freezer
do you have voltage at the compressor? if not you have an open circuit or bad t-stat. if voltage is present and compressor is not running you have a bad start device or bad compessor. if voltage present and compressor runs you have a refrigeration issue get a new freezer.
Posted on Jul 18, 2008
SOURCE: freezer not freezing
it would apear the stat is the fault. the thermostat is monitoring the temperature of the inner liner and tubing. if the compresor isnt actuly staying on the only part controling it is the stat. if you have the knoledge i would sugest you bypass the contol with the unit unpluged and the plug it in to conferm the fault was the control. p/s you may have a friend who has some knoledge . the control is a simple switch. just enshure the unit is unpluged. hope this helped
Posted on Oct 20, 2008
SOURCE: Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Posted on May 01, 2009
SOURCE: I have a Zanussi chest freezer. What does the red
its too warm,could be iced up or worse.
Posted on Aug 12, 2010
SOURCE: I have an Electrolux Intuition Chest Freezer. The
you need to clean the condensor coils with a brush or compressed air
Posted on Oct 01, 2010
Mar 10, 2016 | Freezers
Aug 14, 2014 | Freezers
Jun 26, 2014 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
Mar 06, 2011 | Frigidaire FFN15M5H Chest Freezer
Dec 17, 2010 | Woods Chest Freezer C1501W3
Aug 22, 2009 | Freezers
Jul 07, 2009 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Jul 05, 2009 | Kenmore Freezers
Apr 26, 2009 | Freezers
391 people viewed this question
