I have an A85 powershot. It still works despite its age. But it only works without the memory card. It turns on when there is no memory card. But if I put the memory card in, it won't turn on. Any idea what could be problematic?
If you have already tried different memory card than there is something to do with the memory card slot it will be good to try open your device and clean the card holder with spirit.
Testimonial: "Thanks for you answer. I'm afraid I have no other memory card. And I don't want to buy another one for that old device. I already open my device and clean card holder. There's seem to have a connexion problem but only when I insert the memory card. I try that : I open the door with card holder without card. I press the little plastic switch to let the device believe the door is closed. I switch the power button on. The device turn on. As soon I put the memory card in the card holder, the device turn off."
SOURCE: Canon PowerSHot A85
Hello, please check this link: http://www.imaging-resource.com/badccds.html If you need more info please advice. Arpi
SOURCE: no memory card error on canon powershot a400
Maybe you have to format the card before the camera recognizes it
SOURCE: canon powershot a85- blurry images
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
SOURCE: No Memory Card Error
May memory reader correpted or insert reversely memory card into reader.
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
