Cleaned the HSI and flame sensor. This indicates a power switch problem, and there are 2 power switches. if fan not blowing enough air sail switch will shut down possible bad fan motor There is sound of water coming from the furnace motor. Resolved: I found the problem to be water in the inducer motor. Dismantled the motor and drained the water, noticed that after the furnace shuts off there is some water getting drained. The water in the motor seems to have affected the pressure switch. Thanks for all responses.
Be sure your vent to outside is clear for sail switch air flow. Sail switch is called an air prover. Check reset and be sure gas is present. If it has a good igniter and flame sense them meter the motor. Motor may be to slow to close switch
Check out the pressure switch .
Testimonial: "Resolved: I found the problem to be water in the inducer motor. Dismantled the motor and drained the water, noticed that after the furnace shuts off there is some water getting drained. The water in the motor seems to have affected the pressure switch. Thanks for all responses."
SOURCE: Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
SOURCE: Goodman GMNT furnace goes into 'lock-out'.
check to see if your intake pipe or vent is clear this could cause a flame jump and make it look like a bad flame sensor let me know if this helps
SOURCE: Sony FD Trinitron WEGA Tv KV32FQ86E two flashing led
Check 470 uF 450 V in the power supply. I don't know if the chassis is the AE-5, but I had a similar case and the capacitor was bad.
Please tell me if it worked.
e-mail: [email protected]
The high voltage power supply is going bad on both units.. Pretty soon, it won't power up at all. For a fact.
Don't try to replace the power supplies, TV's are too cheap.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
