Tablets & eReaders Logo
Question about Acer Tablets & eReaders
I have an Acer Iconia A3 B30 tablet. I am trying to set up hotspot in network setting and all I see in setting is the VPN. How do I access the file for setup?
Posted by John DeLeo on
1 Related Answer
Mister Danger
  • 5631 Answers
SOURCE: How does one enable settings to keep screen on for more than 30 seconds for the Acer a3 iconia tablet
Do a factory reset
Acer Iconia A3 A11 Recovery Boot ITFroccs hu
If still acting up, take it to repair
Posted on May 24, 2015
Acer iconic a3 a10 password reset or factory restore
Pay attention from where he holds the power and volume button.
I have Acer Iconia B1 it has put itself in safe mode I've tried everything but cant acess wifi my settings show I have a strong signal and connected but the WiFi ?? symbol is not blue, what can I do
I'm afraid you can't access wireless Internet while in safe mode.
Try pressing Alt and F10 when turning on your computer and choosing safe mode with networking instead of safe mode.
5helpful
I have just bought an acer iconia w3-810. When starting the set up process I can't connect to the Internet. It says I have no connection to internet. Tried setting up a network and it can't find my...
try connecting to another location like the public library. it could be that your router security setting may be set too high.
http://brandzone.bz/files/catalog/upload/5/8/planshet-acer-iconia-w3-en.pdf
Wireless networks - 29
Installation speed and simplicity Installing a wireless LAN system can be fast and easy and eliminates the need to pull cables through walls and ceilings. Components of a wireless LAN To set up your Wireless network at home you need to have the following:
Access point (router)
Access points (routers) are two-way transceivers that broadcast data into the surrounding environment. Access points act as a mediator between wired and wireless network. Most routers have a built-in DSL modem that will allow you access to a high speed DSL internet connection. The ISP (Internet Service Provider) you have chosen normally supplies a modem/router with the subscription to their services. Read carefully the documentation supplied
with your Access point/router for detailed setup instructions
Why has my acer a3 screen gone blank ?
The program of your unit is wiped out. reprogramming is the solution.
2answers
How do i take a screenshot on an acer tablet
I'm not certain, but I believe that is a function of the Android OS. Mine has an icon which takes a screenshot... and I often do, even when I do not want to. I found nothing about screenshot in the Acer manual, so I am not sure how you can make this a function. The manual is at:
http://www.cellphones.ca/upload/manuals/acer-iconia-a3-manual.pdf I hope that perhaps this can help steer you in the right direction.
Can't find how to change the date or time
System
Setting the date and time
To set the date and time, tap
APPS
Settings
Date & time
Tip
: If you travel frequently or live in
an area that uses daylight saving
time, and have mobile network access, activate
Automatic date & time
from this menu. Your tablet will set the date and time based on information
it receives from the network
1helpful
Reset my passoword on my acer iconia A3-A10
How to reset password Acer iconia A3 please help me
Top Acer Tablets & eReaders Experts
Marvin
Marvin
NOEL
NOEL
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
