Question about Refrigerators
Norcold n823, the mode and temp buttons are not working
Posted by Mike pennington on
Brad Goodale
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
Circuit board problem replace board.
Posted on Nov 03, 2018
1 Related Answer
holeinthenet
  • 51 Answers
SOURCE: N 512 Norcold RV 3 way. Fridge and freezer work in all 3 modes. When outside temp is in the 20s it stops working. As the temp warms up it will start working again. Is this normal for this fridge.
I had the same issue with mine,I found it just keeps the food in the refrigerator from freezing when it’s too cold outside
Posted on Feb 01, 2018
Won't operate in gas mode. Get code with a "wrench 3."
time to get the service person back under warranty
don't try repairs yourself as that voids the warranty
because you had to replace the regulator so early after purchase , it suggests problem in the gas lines(dirt or filings) that have blocked up the gas jets . problems on the other circuits could be again installation faults
I'm sure that you will make your dissatisfaction known to the company
May 05, 2016 | Thetford Norcold 3-way RV Refrigerator...
THE HIGH TEMP.LIMIT SWITCH IS OPEN NEED LOCATION
The high temp switch connects to your power board at "Limit In" and "Limit Out". Follow those wires to the switch. I would see if you're under the Norcold recall. Give them a call and check. If you're not, here is where you can get an upgraded thermal switch:
Norcold High Temperature Limit Switch V2 0 by ARPrv
Apr 24, 2016 | Norcold Inc Norcold 1210IM Refrigerator
My Norcold N611 frig code flashes 3 time every few second and doesn't go into A/C mode and will only go into gas mode when the switch is in auto mode and the interior light stays on even when the
The N611 will flash 3 times as an AC heater fault. If your AC heaters are ohming out properly (48 ohms of resistance), then you have a bad power board. If the AC heaters are not showing around 48 ohms of resistance, replace the AC heater. It's going to be one of the two. Here is an article on it:
Norcold Fault Codes AC HE or On light flashing 3 times What to do
Aug 16, 2012 | Refrigerators
Want to reset board on N611 norcold ref
http://www.ehow.co.uk/how_7679848_reset-norcold-control-board.html
Jun 09, 2011 | Thetford Refrigerators
Norcold mod 1200 does not cool well in Az. during the summer time
air circulaton over the cooling unit on norcold is critical get out you owners manuakl look up baffels and make sure all are in tact and also no animals have made a home behind you refer you have done all you can do inside the problem lies on the outside of the refer where the cooling unit is
Jul 22, 2009 | Thetford Norcold DE0051 Refrigerator
Norcold Fridge will not work on LP gas while traveling.
One of two problems. The auto switch is bad or the lower circuit board is not doing its job. You can call norcold technical or take the board to a service center and have it checked with the tester they should have. The lower board retails for 176.00. I looked at my tech file and it is a little vague on your particular situation. If I were repairing your fridge I would take the smart route and call technical. Hope you get your problem solved. If you need more help please feel free.
Regards
Mar 24, 2009 | Dometic NDR 1292 Refrigerator
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
