SOURCE: I can't unfreeze my Samsung A707
Try 123UNLOCK.NL My SGH707 read "PHONE FREEZE". That's almost impossible to fix, but they did. They are a Samsung unlock outfit. Give it a try. It sure worked for mine.
SOURCE: samsung galaxy android unlock..cannot unlock my
Hi, I have a couple of idea for you to try.
1) Log in to your google account on your pc, the same account you registered for your phone
2) After logging in look at the top right corner of your inbox/email page, it would say your google username. Like say if you name is John, and you have a google id thats registered to your galaxy s as , [email protected]. Now this google id on the top right corner of the page would be displayed as [email protected]
3) Type in the google id, thats visible on the right hand top corner of your page (like [email protected]) into your galaxy s handset locked page, and type in the password.
TADA AND YOUR ON TO THE NEW SCREEN TELLING YOU TO PUT IN ANOTHER PATTERN.
or theres this one:
Take out the battery, the sim card, and the SD card leave the phone for 2 to 3 hours like that.. Put everything back in and boot up the phone.. This should work.
You could try this instead of waiting 3 hours, just remove battery and press power on switch for 20 seconds but this may not work.
or if you've tried everything, the only other way would be to take it to a Samsung mobile phone shop.
or do a factory reset:
THIS WILL ERASE ALL YOUR DATA THOUGH
Go into recovery mode - vol up & home & power. Once in the menu, select factory reset.It may take you a couple of attempts to get to the recovery mode but it does work, just keep trying.
Regards
Mike
SOURCE: i need to figure out how to un freeze my at&t samsung cell phone
If your phone displays the 'phone freeze deactivation fail' then your phone has gotten hard-locked; it will not accept any unlock codes. This problem can only be caused by improper unlocking. Basically this happens if you or someone else has already entered 5 wrong unlock codes on your phone.
You can get the unfreeze code, NCK code and SPCK code from third party. After unfreeze your phone, you have to enter the NCK code to unlock and use it with any gsm network in the world. i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website
SOURCE: My Samsung galaxy Android device got water damage
You need to draw out all the moisture before you try charging the phone. Placing the device in a container with dry uncooked rice for 24-48 hours will do this. A oven set at low temps can also do this but is way risky. (Trying to keep the phone about 150 degrees for thirty minutes) rice is the safer method
SOURCE: How to transfer files from library computer to my android j3 phone?
If your phone is OTG compatible ,you may connect your phone with OTG cable to your computer ,try transfer of data.or you may install SHAREIT App.in your phone(Android)and install SHAREIT app.for Windows in your computer and try transfer.
