Check your freq. .counter and set for E band. Look at the .counter and it will tell you what channel you are on
The switch with E/A, F/B, G/C, H/D is the band selector. the switch with PA, FM, AM is the mode selector. use this switch if you want to work on FM or AM.
here is a link if you want to download the manual:
http://cbradio.nl/galaxy/Manual_Galaxy_DX44V_ENG.pdf
SOURCE: rf gain has no effect on radio at all/galaxy 44 model
test resistance of the variable resistor ( rf gain) to make sure the pot is not dry use some electrical lube behind the pot to clean internal connections. pot resistance is stamped on the back.
other than that if your receive is week you have most likely a fault in one of the filters or pll
