Question about Bose Audio Players & Recorders
Bose error 10 lifestyle 28 series 2, getting no sound
Posted by Kelly Wessels on
5 Related Answers
Anonymous
SOURCE: connecting lifestyle 27/38 to psp3
Your Bose system doesn't lead sound trough hdmi.
You must connect the optical cable with your lifestyle.
Change the sound connectionsettings in the menu of your ps3.
You also need to assgn the optical connection in the setup menu of the lifesyle. e.g. optical=aux.
Posted on Jan 12, 2009
Anonymous
SOURCE: I have a Bose Lifestyle 28 and want to hook my ipod up to it.
if there is a rca input available you can go to a local electronics store such as radio shack and pick up a rca MALE to 1/8 MALE cable
Posted on Feb 03, 2009
Anonymous
  • 18 Answers
SOURCE: bose lifestyle 28 will not come on?
The Bose Lifestyle System has two power connection. One is the adaptor for the media center/DVD and the other one is the bass module/ subwoofer. Both has physical indicators showing that power is present. If your pwoer adaptor is ok, then the media center display should show "BOSE LIFESTYLE SYSTEMS" on startup. The bass module power module should be OK when you see a green blinking or steady linght underneath.
If only the media center/DVD has no display then there is something wrong with your pwer adaptor and should be sent for repair.
Hope I have helped you
Posted on Apr 08, 2009
Anonymous
  • 76 Answers
SOURCE: No sound Bose Lifestyle 38 III
I am quite sure that the indicator lights should be green. The blinking yellow likely indicates that there is no communication between the head and the audiomass. Verify that the connections are tight and then try powering off (unplugging) the system (both head and audiomass) for 30 seconds and then powering on again. That will often re-establish communications.
Posted on Aug 22, 2009
Anonymous
SOURCE: Bose - Custom EQ Error: 10
Hi, I have just had the same problem and the advice from BOSE was to turn everything off and disconnect the sub from the main unit, wait 10 mins and turn everything back on, making sure to turn the sub on first.
As it happens i then noticed I had connected the sub via the BOSE link speakers plug to the main unit rather than the correct "MAIN" socket. - so if you are reading this you know I am a fool! But the sound now works.
Basically BOSE confirmed the reason for error 10 is that the main unit is not detecting the sub and speakers.
Anyway, I hope my foolish mistake, helps save time and blushes for anyone reading this link.
J.
Posted on Dec 31, 2009
I have Bose lifestyle 28 series III. Suddenly it stop working and now showing an error 10. Could u pl. help me solve the problem.
hi ,
the main problem you have is that the head unit does not recognise the sub .
unplug everthing and let it unplug for minimum 10 mns .
than turn the module on
this should get rid of your problem
2helpful
PS3 to Bose Lifestyle 28
hey, this is how i have mine set up.
Bose to PS3 via Digital Audio Optical
PS3 to TV via HDMI
This way you can get Full 5.1 surround sound, and good picture quality, also, go to the bose menu and set the optical source to your PS3.
1helpful
Error code 10 during sound calibration
Please ensure that you have turned on the Accoustimass module, this can cause communication errors when calibrating. Also check that all connections are correctly plugged in as if one is not quite sat right this may give the error, just try unplugging them and plug them back in.
2helpful
1helpful
Connecting lifestyle 27/38 to psp3
9helpful
4answers
J.
3helpful
Bose Acoustimas with error 10
Error 10 is either a disconnect from the audio input cable (check the pins on both ends) or the Acoustimass module has no power. Check the outlet etc. If resetting it (unplug both components for 30+ seconds) doesn't fix the problem. Call Bose for a repair.
Error 10
Yeapp Buy another bose!!
Top Bose Audio Players & Recorders Experts
Ekse
 Francisco Mauricio...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
