Question about Boston Acoustics Audio Players & Recorders
What size is the subwoofer fuse for the Boston Acoustics tvee model 20?
I know it's a 1A 250V. I just don't know the actual, physical size it calls for.
Posted by Justin Adams on
2 Related Answers
vetteman3002
Rodney Clark
  • 2299 Answers
SOURCE: My subwoofer with my new
Is the subwoofer all that is cutting off? Or is it both? You may have already explained, but all I can see is the original question. Thanks!
Posted on Dec 14, 2010
SOURCE: I have a TVee model 2 from Boston Acoustics
Hi jdmowen,
I see that you need help since you lost the hardware for setting up you TVee Model Two Speakers.
What hardware are we speaking of? check the links I have provided, one of the links will be the manual and the other links will be where you can get the parts that you might need.
Manual
Parts Boston Acoustic Website
Parts Reseller
Parts Other Resellers
I hope this will help.
send me a message if you need a specific part maybe we can get info for it.
mvincentc
Posted on Jul 04, 2011
Programming time warner remote to boston tvee volume
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process. Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com) Using Pre-Programmed 3-digit Code method -Turn on soundbar - Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit. - Point remote control toward the soundbar and enter code (447 for Boston Acoustics) - Press the device button again to store the code. The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me. Step 2: Program your remote from the Boston Soundbar. - Press the power button and the volume up button simultaneously until the indicator light flashes orange. Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming. - Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange. - While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed. - Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote. Good luck, I hope this helps. -Deidre.
Dec 05, 2012 | Boston Acoustics TVee Model 25 Sound Bar...
Volume on Boston sound bar will not go up very high
There is a internal problem with it, Take it in for repair, out put transisters are probally fried,
Dec 02, 2012 | Boston Acoustics TVee Model 20 Soundbar...
Tvee model 25
Have you checked all your wire connections? To make sure thier not loose.
Aug 05, 2012 | Boston Acoustics Tvee Model 25 Sound Bar...
Red status light will not go off or change on Boston A TVee model 2 soundbar.
I am also having the same problem. It was working fine until we moved. Plugged it in at the new house and nothing but a red light. Sub is green though.
Jul 10, 2012 | Boston Acoustics TVee Model Two TV...
Where is the fuse for a Boston TVee Model 20?
Same thing here, I'm afraid, my Boston TeeVee 20 sub randomly goes on and off. I've taken it apart and to see if it might be the fuse and unfortunately the fuse isn't a standard unit, rather it's a "built in thermal fuse", see picture. This isn't going to be easily switchable, and in any case I'm not convinced the fuse is the problem as the sub sometimes does come on--sounds more like a wiring issue to me. Shame as now that I've got this opened up it's clearly a well-made device, other than the issue we're running into. 11_3_2012_5_50_45_pm.jpg
Jan 24, 2012 | Boston Acoustics Audio Players & Recorders
Boston tvee doesn't work
check cable power and check cable connection
Jan 15, 2011 | Boston Acoustics TVee Model Two TV...
Fuse
Its actually a 7A 250V fuse. Unfortunately, I have not had any luck finding it. Also, 7A 250V fuse come in two sizes, a large and a small. So you will need the small
Aug 03, 2008 | Belkin TuneBase FM (F8Z049-BLK) Car...
Suround sound dvd
Get a Boston Acoustics Tvee Soundbar System.
Dec 06, 2007 | Boston Acoustics TVee Model Two TV...
114 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Harrie
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
