Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
My Hoover Wind Tunnel has a burning smell when running. I replaced the belt, but this didn't help.
Posted by julie_kuehn on
Anonymous
  • 32 Answers
Its clogged my vax does that burning smell when it gets clogged up thats for the five minutes before it overheats and stops
Posted on Aug 31, 2009
I replaced my belts on my premium hoover wind tunnel and the roller barely moves. Also, I keep getting a rubber burning smell. I'm confused weather if it's worth to have fixed or buy new.
More then likely whats going on with your roller is on each side of the roller is bearings and hair or other things build up and makes it really hard to rotate.Take the roller off the vacuum and check you may be able to clean and oil them.
Jun 22, 2011 | Hoover Premium U45900 WindTunnel Bagged...
I have a windtunnel vacum cleaner. When I
It might be a slipping rubber belt, is the brush roller moving when you look underneath? If it's a self propelled machine there might be another slipping belt. Friction from fast rubbing rubber can smell like it is burning.
Jan 16, 2010 | Hoover Company Wind Tunnel U53019 Upright...
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
How to change the V belt on hoover wind tunnel U6435-900 ?
Below I have listed a link to the manual which has instructions and a link to the V belt you need.
Windtunnel Manual
Windtunnel Replacement Belts
Nov 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuum shuts off and has a burnt smell
Try removing the drivebelt, and try running it to test like this. The brush bar will not turn, but it should function normally without smell at this point. If it doesn't, you may need a new motor as I think the brushes may have worn down - producing an electrical type burning smell.
If it runs fine without the belt attatched, then there is probably a build-up of hair or threads at each end of the roller stopping it turning freely. With the hoover off, check it turns freely and easily. A small metal nail file or similar is usually a good tool to clear it.
If the roller is stiff, the belt will not turn easily, and overheat on the motor spindle - causing the burning smell.
Jan 08, 2009 | Hoover Vacuums
Rubber smell, Hoover
Well it sound like you do need a new belt because of how the smell is you might want to stop using it because the smell comes from the burning and over heated belt my solution would be to get a new belt and that should fix it if you need anything else you know whre to find me.
Jun 30, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Changing belts on Hoover wind tunnel U6401
Take off the bottom plate covering the brush roll, 4 screws. There are 2 belts, if you replace both, put the V belt on 1st, then stretch the flat belt over the motor shaft, then over the bigger pulley along side the V belt.
May 20, 2008 | Vacuums
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
2,719 people viewed this question
Top Hoover Vacuums Experts
Marvin
Marvin
Mike
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
