Mastercraft electric chainsaw. Email only no access to phone.
SOURCE: chainsaw wont oil the chain and bar it is a poulan 2000 woodsman
It's probably the oiler check valve located on the crankcase just in front of the clutch. You will probably need to remove the clutch and sprocket to get at it.
SOURCE: stihl 180 chainsaw,lack of oil to chain and bar
hi there i had this problem check bar studs make sure there tight bar must be flush on chainsaw body not on stud flange if bar is on stud flange there is a gap so oil leaks out near sprocket and not in bar oil channel
SOURCE: talon petrol chainsaw ac3100, bar lurication
Talon chain saw wont start, have spark, but fuel drips from exhaust when attempting to start, saw only used a couple of times any suggestions?
SOURCE: Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
I have been using regular chainsaw oil and I think it works ok. I inherited one of these and would like to find a spare chain and also a manual. Can you give me any info? Thanks
Tim
But don’t mix bar oil with gas obviously. Only what’s recommended by manufacturer
This is an electric chainsaw. I understood I didn’t have to mix with gas??
There should be NO GASOLINE involved in any part of an ELECTRIC chainsaw. Use bar and chain oil only in the oil reservoir.
That’s what I though. Thank you for the info.
