Question about Tablets & eReaders
PLEASE I USE IRULU BUT I WAS TRYING TO REINSTALL IT BE IT WENT OFF NOW HAVE CHARGE THE PAD BUT HARD TO REINSTALL PLEASE HELP.
Posted by ADEDOYIN TOLU on
Ps Daengr
    Habit-Forming:
    New Friend:
  • 27 Answers
You need to fully charge the tablet and THEN do a factory reset. The hardest part is waiting.
Follow the steps provided below to perform a Hard Reset on your iRULU Android Tablet:
  1. Turn your iRULU tablet off.
  2. Press and hold the correct key combinationto boot your Android tablet into Recovery Mode.combinations, which include:
  • Home button + Volume Down button + Power button
  • Power button + Volume Down button
  • Power button + Home button + Volume Up button
  • Power button + Volume Up button
  • Power button + Volume Up button + Volume Down button
  1. Release the power buttons once your screen turns on, and the device vibrates. Keep holding the other buttons for 10 seconds.
  2. Your Tablet should now boot into Recovery Mode.
  3. Scroll down to the 'Factory Reset' option using the volume down key.
  4. Select the 'Factory reset' option by pressing the power button.
  5. Now your Tablet will start the hard resetting process.
Once the process begins DO NOT press any buttons and don't try to turn the device off.
Your tablet should now be reset.
Posted on Oct 26, 2018
1helpful
Unable turn irulu 10 tablet off. Frozen. icons wont do anything.holding power button in for awhile, tried Crtl, Alt, and delete button at same time & stays on. Please help asap. Thank you Bonnie
Try a hard reset. The 10" Irulu has a reset on the right bottom edge. You'll need to stick a sharp pointy pen that fits in the in the small hole, push. Press the ON button and see if it starts. Resetting will change the time and date to the default setting of your unit.
How to get my irulu expro x1 unstuck from boot load
Hi a irulu error 1x stays or repeats the startup how do I stop that ? Can get it to start?
2answers
I bought two irulu tablets but the both broke in the same exact spot, in the charging port. the pin broke out and i cant charge them now. Is this a flaw with all irulu tablets or just the two I bought
I would definitely follow your friends advice. If they are under warranty, you should be able to get them fixed. If the battery can come out of the tablet, you can use a universal charger to charge the batter, but I am assuming it doesn't.
If you know how to solder, then you could replace the port yourself, but this is risky, so getting pro help is the best bet.
2answers
Irulu tablet wont charge
These are the videos which will help you why tablet is not getting charged and solution to overcome
Try to use USB and charge it with it
and then after 10 min try to start the tablet
Will not turn on
check the voly out in you vcd adapter if this exist go to open you pad and rebulding soldering the conector volt in and then ready you pad work again please vote
I turn it off and went to it back on and now it want power back on
It is a bit hard to understand your problem.
I assume that you switched it off and is not working.
From experience with other tablets, I would first charge it. (Verify by substitution that the charger is working). Ideally use an external charger and not a computer USB.
Then, if satisfied that the tablet has fully charged, I will press and hold the power on button for up to 30 seconds until the screen stirs.
A better descrition of your problem in clear sentences would help.
5helpful
Reinstalling operating system on Irulu AL 101
you have to use the phoenix card to reinstall the stock firmware. you can find it at Irulu.com go to drivers. i just did a reinstall using the same process.
Tablets & eReaders Logo
Top Tablets & eReaders Experts
matt
matt
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
