The fuses are usually inside the set. But fuse failure is rarely the problem. It usually means the set is defective and may need a new power board - or something else. If set is still under warranty take it authorized service or call them to see if they will do service in the home. If out of warranty you will need independent service agency.
If you are technical try googling for common problems and repairs for your model. There may be forums or discussion groups that can lead you to methods of simple troubleshooting for your detailed symptoms.
