Question about Electrolux Dishwashers
Where I can order PCB control board of my Electrolux washing machine EWF8556 model.
Problem occurred wont drain after last spinning period.Have checked Drain pump, in good condition,no clog on drain pipe.After draining manually.will operate normally.
5 Related Answers
Anonymous
  • 97 Answers
SOURCE: Zanussi FC1200W
have you checked the filter behind the flap on the front of the machine, this could be blocked. if the machine is full of water though you will have to manually drain it by putting the grey outlet hose into a bucket or a washing up bowl. you will also need one or two towels to place on the floor because there wil still be a bit of water left in the ipes even though the drum is empty.
hope this helps
Posted on Jul 28, 2008
Anonymous
SOURCE: Washing machine will not drain
I have a maytag washer that when it fills with water it wont drain out..the spin cycle just makes a noise and it wont do anything..any ideas what i can do to fix it thanks
Posted on Nov 24, 2008
Anonymous
  • 1122 Answers
SOURCE: Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Posted on Apr 24, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: NEXXT Premium will not spin or drain
There should be a filter located at the bottom right front of washer behind drop down flap or plastic cover.
Unscrew anti-clockwise to remove and clean.
Posted on Jan 23, 2010
Testimonial: "Thanks. Great advice. We found a sock clogging the drain."
My Electrolux 8kg time manager lifestyle washing machine got overloaded, now won't wash or spin .. Still drains.. Any ideas plz Tia..
1. Check belt if it is broken.
2.Is the motor running?
3. Is the program /display running as normal?
I have try to fix those machine, all of them are the PCB not working.
Good luck
Oct 14, 2016 | Electrolux Washing Machines
Electrolux washing machine wont spin all the way
Not a solution, but I wonder if it thinks you've either selected no spin or it thinks the machine isn't drained and so won't spin or it thinks the load is unbalanced. You seem to have done everything logical so far.
Also look at all all connectors
Logic seems to dictate that if the motor/motor drive functionality and other diagnostics don't show any problems (although I must admit if it were possible I'd like to try another motor control board just to convince me it wasn't implicated) then it must be a logic/ sensor problem and maybe diagnostic mode doesn't check all sensors in the same way as would happen in normal use? Sorry I can't be of more help. (The motor brushes are probably ok but I'd check them anyway while you are in there) Do let us know if you find anything.
Apr 16, 2014 | Electrolux EIFLW55HIW Front Load Washer...
Electrolux front load washing machine ew10001 spin cycle slow on "SPIN" setting runs fine through regular wash setting? any ideas?
Hello jamespeattie - Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Jan 02, 2013 | Electrolux EW1000i Front Load Washer
My beko washing machine wont spin ive replaced pcb board but to no avail if anyone can help much appriciated
Hi christophe if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Oct 30, 2012 | Washing Machines
I have an electrolux washing machine model atfb6700 front loading bought in 2008 that does not spin. It will turn on the wash cycle but the motor buzzes in both cycles. Is it the motor or motor boards?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The motor is toasted...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 09, 2010 | Electrolux Washing Machines
Beko washer
hi there.....this problem can occur with the W510 if you have selected the 30minute wash and loaded a full wash load....the 30min wash is to be used with a 2.5 kilo load only.....if the problem is occuring in other selected programs then you can check (a) is the machine draining...if not check filter and pump..(b) check the motor plug that it is secure....remove it refit and test.....check the carbon brushes in the motor....and lastly if al the above are ok then you got a faulty PCB Board.
regards Sir Galahad
Jul 29, 2008 | Frigidaire FTF530FS Front Load Washer
Dishwashers Logo
65 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Marvin
Marvin
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
